Hey guyz,
first of all, Yes! i did a search on SAU and GAU(google Australia) and did not find what i was looking for.
Does anyone know how i can wire my alarm to the horn in the car?
everything else on the alarm is working fine.
1) i have the negative wire to trigger the horn, but the manual says i need a relay.
(a) Is there a relay for the horn and can i use the existing one? or should i get a new one?
(b) If i should get another relay, how do i wire it?
© and if there is a an existing relay for the horn, how do i wire the second relay to it? (if i dont make
sense then then i ask for your forgiveness)
2) Where do i wire the Common Negative Door Trigger? Where can i find the wire that it connects to?
Please help guyz, u know i love u all.
U can PM me if you want
Cheers :P
Vish
https://www.sau.com.au/forums/topic/289403-alarm-wiring/
I hooked the Negative horn Trigger from alarm to the Negative wire from horn that goes to the horn Relay.
I did not add a new relay.
It worked but just want to make sure its right.
i have attached a diagram of the relay i drew in MS Paint.
Can i hook the alarm trigger wire to the negative wire that comes from the horn? i tried it and it worked, but i am not sure bout the amps coz the alarm instructions say it can only provide upto 2amps and the horn will require more.
https://www.sau.com.au/forums/topic/289403-alarm-wiring/#findComment-4847549
ok, i ended up buying the cyclops alarm upgrade kit and have installed the Battery Back up Siren, but the siren has 6 wires. i connected 3 wires. 1 alarm, 1 neg, 1 pos and it works but i dont know what the rest three wires are for?
and still need help with the negative door trigger? where do i connect it?
Cheers
https://www.sau.com.au/forums/topic/289403-alarm-wiring/#findComment-4848641
