  • Replies 70
Oh boy - I'd rather not go there !
he he he he
Moanie - long time no see ! (my fault - no car)  :rolleyes:
what happened to your car?? i still walk down pitt street looking for window wipers to put up!! hehehe...i did that to some skyline at the entrance...hehe...wonder if hes on this forum!! :(
