  • Replies 63
Posted Images
Spudnic is from Geelong...
My mrs family is(and my mrs, but she moved up here) so when i am down there i keep an eye out for imports... only seen three tasteful ones EVER. Seen a couple of 180's done sydney/geelong spec :banana:
https://www.sau.com.au/forums/topic/289413-g-town/#findComment-4845629
Just wondering if anyone was planning on going to the meet in Melbourne tonight?
Thead HERE
If there is anyone going up we could meet up and cruise together, thinking about skipping the dinner and leaving geelong at 7pm?
https://www.sau.com.au/forums/topic/289413-g-town/#findComment-4890215
  • 3 weeks later...
im from geelong had a black r34 gtt with nismo kit, and black 5 spoke 18's with silver dish, but my car isnt around anymore unfortunatly...
moogley i recon i saw u a street up from ryrie 2 weeks ago sat night?
over the past couple months theres been a heap more skylines poppin up i recon... a few N/A r34s with red P's..
some of em have 2 b on here i recon
https://www.sau.com.au/forums/topic/289413-g-town/#findComment-4917779
Only ever seen a 32R there, i'll keep an eye out for you. I'm in the white 34 with black te37s
i havnt seen u around either lol.. we probabaly park opposite sides of each other haha
i've seen a couple r34's one silver sedan and peterw's r34 2 door..
ill keep an eye out for ya though :laugh:
https://www.sau.com.au/forums/topic/289413-g-town/#findComment-4919816
ill keep an eye out for ya though :D
i've seen a yellow 34 coupe in that carpark behind the library a couple of times
https://www.sau.com.au/forums/topic/289413-g-town/#findComment-4920457
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
