i had a fellow sau member put on a bosch (032 or 040 or somethig) internal fuell pump and the installlation went well....drove it for 30 mins around and it was running well....as i was going home and then i had a a quick lose of power and the engine would slowly die.Tried starting the car and it wont start at all...
i could hear the fuel pump switching on but it wont start..It would just be cranking on the ignition...
Called him up and he told me to check my fmic piping and afm (there could be a leakage not getting enuff air) and check the fuel pump wirings ( a wire would of came off). I checked em all but it still wont start...
can someone help me out as please....it seems it wanna start but something is stopping it....
cheers
https://www.sau.com.au/forums/topic/289415-plz-help-car-wont-start/
Take the fuel hose off the end of the reg...
See if fuel is coming out.
Sounds like a botched install of the fuel pump - is it a genuine BOSCH? Plenty of fakes on the market - usually easy to pick as they are just too cheap.
yeah he does, and yeah if no fuel then maybe the stock wire just isnt big enough to power the 040, im guessing the 040 is similar to 044, when i got mine done u run another wire that follows the stock on thats a thicker core, otherwise it'l melt like it did on my mates vl after he got a respectable well known dyno'r in sa to put it on...
car feels like ders no fuel going thru the engine....fuel reg might be faulty..what do i do now??
Have you pulled the fuel line off that goes to the reg and turned the key to on? Does the fuel pump out?
If not the pump pickup may have fallen off.
    • If you do go with drain back, make sure everything is foam or wool filled so it actually does something, and ensure there is a screen somewhere in the drain to catch anything that comes loose from the packing. I don't drain back
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
