i had a fellow sau member put on a bosch (032 or 040 or somethig) internal fuell pump and the installlation went well....drove it for 30 mins around and it was running well....as i was going home and then i had a a quick lose of power and the engine would slowly die.Tried starting the car and it wont start at all...
i could hear the fuel pump switching on but it wont start..It would just be cranking on the ignition...
Called him up and he told me to check my fmic piping and afm (there could be a leakage not getting enuff air) and check the fuel pump wirings ( a wire would of came off). I checked em all but it still wont start...
can someone help me out as please....it seems it wanna start but something is stopping it....
cheers
https://www.sau.com.au/forums/topic/289415-plz-help-car-wont-start/
Take the fuel hose off the end of the reg...
See if fuel is coming out.
Sounds like a botched install of the fuel pump - is it a genuine BOSCH? Plenty of fakes on the market - usually easy to pick as they are just too cheap.
yeah he does, and yeah if no fuel then maybe the stock wire just isnt big enough to power the 040, im guessing the 040 is similar to 044, when i got mine done u run another wire that follows the stock on thats a thicker core, otherwise it'l melt like it did on my mates vl after he got a respectable well known dyno'r in sa to put it on...
car feels like ders no fuel going thru the engine....fuel reg might be faulty..what do i do now??
Have you pulled the fuel line off that goes to the reg and turned the key to on? Does the fuel pump out?
If not the pump pickup may have fallen off.
