I have a set of RB25 stainless manifold with T3 flange and a set of caster rods with caster adjustable Nolethane bushes for sale in good condition.
The stainless manifold mounts the turbo at stock position, it has a very small hairline crack for about 2cm long, doesnt show up on photo, at the collector close to the turbo flange which can be easily repaired and reinforced at any exhaust place.
It made turbo spool up quicker, and changed the exhaust tone to make it sound a lot smoother. It was purchased new for $1000, $100 for quick sale!
Caster rods are in good condition, easily pulled more than 7 degrees of caster at maximum adjustment, and gives really good turn in response. $55
Happy to consider offers, but please be reasonable
PM me if you're interested, items are located in Kograh, can post it at buyer's expense, need to clean these out soon!
Edited by chiksluvit
    • Hey all, I'm working on a project car and I believe I made some mistakes. I'm looking to remove the clear coat from my car on most panels (except for panels where the paint has blistered, I will sand this), but wanted to know if these steps are correct?   1) Get a red scuff pad (abrasive one) instead of sand paper to remove the shine from the surface 2) get 400 grit sand paper and go over the entire car with a random orbital sander so the surface is smooth and the primer can grab onto something 3) On the blistered paint, go over it with around 120 grit sand paper, go to 240 to smooth out the scratches, then finish on 400 grit. Anything to add in here or any feedback?
    • Agreed, another vote for the Haltech CAN wideband.  No voltage offset errors is a beautiful thing.
    • Just get a Haltech CAN wideband, no need to wire any delay circuits, or relay, etc. Since I've moved to a Haltech CANbus wideband, I have not replaced a single sensor for over 5 years (if not longer, can't remember when moved to Haltach).
    • Small analogue delay circuit with a relay. Just need a trigger, say, fuel pump running for more than 5s or so? Or, you could go full mental and write a sketch for an Arduino.
