yeah my tip is its a prick of a job, give it to a workshop :banana: you need to press the bushes out of the front of the diff which means somehow supporting the whole heavy thing at the same time. thats after the stuffing around on the ground to remove it, and before the pain of getting it back into place.
let someone with a hoist and proper press do it.
I've used noltec and superpro ones and can't tell the difference
Duncan is right!
However, if you want to do it yourself, this is how I did it:
-it is a diff out job, yes
-drill out the rubber
-use a screwdriver and carefully fold in the flange on the bush
-spray with a s**tload of crc and leave it to penetrate
-work them out with a hammer and screwdriver
It is not pretty, fun or quick. I thought the neighbours were going to call the cops as I was screaming f'n c's all weekend!
I am going to go with the Unique Autosports bushes and make up some new inner sleeves out of stainless steel.
Mike
i was thinking going with unique bushing as well , you get everything you need with them by looks of things
i guess allow 2-3 hours for installation of this?
once diff is out any other maintenance that can be done at same time?
With the Unique option you do not get the inner steel section of the bush you have to re-use the old ones. I f**ked mine up trying to get them out, so getting new ones machined up.
Have not got to the installation part, but it took me a whole weekend to get the subframe bushes and the diff bushes out the subframe (having regular breaks to regain my sanity).
2-3hrs? Not a chance.
i was thinking diff bushes only not sub frame tho, or does sub frame have to come out as well?
does anyone else include inner steel sections .....whiteline or superpro ?
You have to pull the subframe out.
No I do not think so, otherwise you can always buy OEM but you are up for over $140ea.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
