Hey Guys,
Had my 100k service done not too long ago, and since then my auto is behaving weird.
Replaced oil and filter on the auto. Nissan Matic J oil used.
R34 rb25de neo engine with a B code auto box.
Since the service, I seem to have lost my over drive in speeds over 80km or so, that little 200rpm the engine drops when your crusing.
Also, under hard acceleration the gear changes are very rough, slight pause and then throws it into gear.
I also have an ecu consult cable and just have it monitoring, its not showing up any codes, but I have noticed that at speeds less than 100km it shows the same speeds on the display as it does on my speedo. once I start climbing above 100km its a bit off and then by 180km on the speedo its only showing around 160km on the display.
Im wondering if I have a faulty speed sensor.
Anyone ever had anything similar to this?
thanks for any help
https://www.sau.com.au/forums/topic/289421-automatic-behaving-strange/
Is it shift solenoid B? They're a semi-common problem, they start to break up internally and give random errors when the gearbox reaches operating temp. Progressively get worse then locks you in 3rd gear.
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
