it looks absolutley fantastic mike, congrats. how long is a car off the road for wile getting wrapped?
It took us 5 full days. This involved cleaning, stripping, more cleaning, wrapping, refitting, checking over all quality and detailing.
We worked back-breakingly hard throughout the 5 days.
But all worth it. :)
Mike
  • Replies 81
Stupid question, does the "wrapping" destroy the orginal paint? And how much weight is added to the car by doing this wrapping?
The paint underneath is protected during the wrap. Unless the paint was flakey to start with, it wouldn't get damaged.
The weight added is negliable. Vinyl wrap material is not all that thick.
Picture below shows unwrapping, without residue. The CF wrap was on a Cooper S for 11 months and the owner wished a new effect, hence the removal. I started by peeling a corner back, added a bit of heat and subsequently rolled it all into a "ball". Some broke off and some didn't. Afterwards, the roof was smooth and not even sticky. All of the film's adhesion substance remained on the vinyl. The roof did not even require a wash.
M3 special paint has to be treated like a glass baby. http://www.egmcartec...he-matte-paint/
The BMW Frozen Gray M3 is the Munich automaker's new and exclusive offering only for the North American market. So exclusive that the 30 owners of the vehicle will have to sign a paint care agreement before taking delivery of their limited-edition Frozen Gray M3.
The agreement says that the warranty on the vehicle does not cover the matte paint if it is damaged as a result of negligence by the owner, environmental damages or improper repairs.
To take care of your Frozen Gray M3 – BMW suggests the following:
  • Never polish or wax the frozen gray paint as it could lead to a glossy surface.
  • If washing your frozen gray M3 in a automatic car wash choose a car wash that does not apply vehicle wax. Rinse the M3 with high pressure water to remove dirt before sending it through the automatic car wash to avoid scratches from sand, dust and other micro-particles.
  • Remove bugs, bird poo, tree sap, tar, fuel spills or oil immediately using a soft sponge.
  • Avoid strong rubbing while cleaning the frozen paint. BMW sells suitable products for maintaining the frozen paint at your local dealer.
  • Repairs to the paint (scratches, dents, etching) must be completed by a BMW trained body shop. Most auto body shop will not be capable of repairing the frozen gray paint.
Edited by Carbon Demon
yep ive seen a matt paint merc with a 3hr old bird bomb.....panel needs to be repainted. Even those annoying brown thin line mosquito bombs damaged the finish
matt paint is porous, even washing can leave water spots if you have hard water or dont dry immediately. Id hate to see what it'd look like when it rains and then the sun comes out and etches the water droplets into the finish. Not even some super sealants i have can resist water spot etching from our harsh aussie sun
with vinyl, you'd just pull the panel wrap off and re-apply if you mess it up
Edited by domino_z
for a whole car it would be, and when you consider the amount of work that goes in just in prep work, it's understandable
i know they did a really cool time lapse video of the install, ill see if i can grab the url
edit
Edited by domino_z
  • 1 month later...
We just completed a 2011 GTR wrap in 3M 1080 vinyl. It is thicker than normal and has some paint protection qualities.
It was a long job and required removal of the front and rear bumper, spoiler and mirrors. It took a long 5 days.
They definitely are not easy. If anyone wants a quote, contact us through http://appealingsigns.com.au We are in WA.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
