dude, put ur price otherwise they'll close ur thread.
I think I'm for around 12K,becaz the brake pad is pretty new. and this price includes everything with the brake.
$12,000??????
Bahahahaha :P
Are you serious?!?!?!?!?
what's included in the brake kit? callipers, rotors and pads? front and back?
12k may be a bit steep, as you can buy a whole r34gtt for 15-18k now a days...
aim for maybe around $500-$600
:D that would be more reasonable
this thread is really bad, "the brake pad" has only dont 5000km? what the hell does that mean.
you need to give way more detail as to
-what you are selling,
-what the condition is,
-why you are selling it,
-where you are located,
-what the price is for the lot or individual items
-what your contact details are
-photos......
and learn how to "sell" a product.
his thread's a "DEFECT" as well as his username. literally DEFECT i mean.
12.000 AUD??? its more sensible if u sell a 6 pot ALCON carbon brakes system instead of R34 gt-t brakes.
500 is reasonable, and prolly i'll keen on it as well.
It is included callipers, rotors and pads? front and back, I spent 660 for all 4 pads two months ago and now I
bought another brake kit so I need to sell this a lot. Photo will be uploaded late this week after I put the new
brake kit on. It's in adelaide btw, 500 AUD plus posting fee is fine,but without the project mu pads.
that's a reasonable price mate. maybe slightly on the cheap side. good luck with your sale.
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
