hey everyone,
I have only just recently become a 32 owner and already have a few questions if anyone could help.
I've just done an oil change from Royal purple to Motul 4100 turbolight.
They both have the same viscosity range (10w40).
After the change i noticed that my oil pressure is low on idle after driving. Pretty close to zero in fact.
When up in the revs (say 3000 to 4000 revs) the pressure needle doesnt get much higher than 2kg/cm^2
The royal purple that was in it also did the same thing. But the royal purple wasnt very nice to the motor on cold start up, in that i could hear ticking.
So my question..... Is this a normal reading for oil pressure on the RB20??
cheers,
steve
https://www.sau.com.au/forums/topic/289473-oils-and-oil-pressure/
Check the link in my sig
EDIT: Just had another look, doesn't have RB20det in there but you get a good idea from it.
Your pressure seems a bit low, but I'd get a sandwich plate on your oil filter and run an aftermarket oil pressure guage from it before you start freaking out, just in case.
Edited by mosquitocoils
Sandwich plate to the oil filter are terrible.
If you want an accurate reading mount it in the sump.
Chances are that the oil pressure is fine. The factory sender is known, and well documented, to be problematic. Get yourself a manual pressure gauge or take it to a mechanic for a pressure test.
Sandwich plate is not necessary as you can just mount it in the same place the factory one goes.
If you want to replace the factory one, they are approx $210 from Nissan.
a mobil 1 fully syn product what else ?
Royal Purple R&D their product and and the 10w40 has a higher film strength than Mobil1 also.
None of which has anything to do with his pressure. His brand of oil is not the problem.
i know that, just wanted to see if anyone got protective of an inferior product.
Lol. Are you being serious?
How are you supposed to get an oil pressure reading from the sump?
You're 100 right, I got my pressure and temps mixed up, sorry.
But yes a sandwich plate will be less accurate for TEMPS not pressure, again must of been drunk when i posted that :laugh:
A sandwich plate is fine for oil temp as most of them have the end of the sensor in the oil flow, its only a problem when there is no flow over the sensor. Take a look at the data sheet of a typical temp sensor and they are accurate to 5% anyway, this will be the biggest source of inaccuracy unless you calibrate your sensor before installation.
I agree the nissan pressure sensor is very unreliable when old. A new one or aftermarket sensor is the way to go.
Motul oils are the goods. Plenty of track cars run them without any problems. Look at Nissan racing cars and you will usually see Motul stickers on the side.
comes back to the old saying..."if you don't want to spin a bearing...put Motul in it"
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
