hey guys im chasing a late model r32 gtr speedo unit or whole cluster if you dont wanna seperate but must be cheap if thats the case
i need the one which has the 4 screws on the back holding the speedo into the white body of the cluster not the 2 screw earlier version must be able to supply pics of the speedo before i send you any cash or dont bother replying
cheers
cheers
Hey Mate, send me a pic from the back of what you want and I'll see if it matches up with either of the two I have here :huh:
Cheers
Az
i dont have any pics but its easy to tell....
pretty much all the 4 screw ones have a blueish coloured electrical "wiring thingy" on the back... the 2 screw ones are tan
by 4 screw i mean on the back of the cluster where the speedo cable goes on theres the raised up section...on the 4 screw version there is 2 large screws and 2 smaller ones up the top also
the 2 screw version just has the 2 larger screws
if you cant make sense of that chuck me pics and i will :huh:
I have a nismo 320km complete cluster w 56xxx on the clock, 4 screw type with blue wiring membrane... Chasing $350 plus postage, I'll send pics if u keen.
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
