Got picked up last night for blue lights on my number plate but thats not the problem.
I got told i can't have 19" rims or higher. I said "what?" The cop says no car is now aloud to have anything larger then 18's since 4 weeks ago.
And he told me i can have neons on under my car at all times when driving as long as you can't see the GLOBE. Crazy!
Any one know more?
https://www.sau.com.au/forums/topic/289551-19s-and-up-now-illegel-in-wa/
i call bullshit
my 300c srt 8 comes with stock 20 inch rims...
like to this the asshole cop u had give me a sticker for that... id tell him where to shove it.
Having said that, the legality of rims is based on what it came with from factory... u can only go up so many inches and so much more wider then stock...
so 19's can be illegal on some cars, while not on others. =)
Edited by br3ndan
yeah, if your number plate don't have those blue neons on them, your life would have been easier cos you won't be pulled over in the first place...
now the copper decided to make your life more miserable, tough luck for you....
the only colours allowed by ADR and local state laws are amber, or white (for number plate, and reverse). brake light should be red, and turn indicator amber/orange... headlights must be amber or white...
imagine the confusion if someone have their brake light green... wouldnt the car behind the slowing down car add more gas and ended up rear ending the car with green brake lights?
does the tyre placard fitted with compliance listed 19"
I checked mine and the tyre placard fitted includes 19"
that's because 19" is available on V35 series 2, and basically the chassis of series 1 and series 2 are the same, so the 19" is permissible on any V35.
providing the width is not of crazy sizes... but looking at the link posted by andy, looks like you gotta stick with 19x8", keeping the width always 8"
He said anyone with higher would get a warning then have a week or something to change them. He also said it's not illegel to sell them so dealers and tyrer shops can sell them.
I guess it's only a matter of time before the word gets around and people start getting pulled over more.
He did quote the law to me.
You've been duped by a cop who "thinks" he can pull one over you. Ahh country cops, so "up with the times".
We are all governed by a national ruling NCOP14 http://www.infrastructure.gov.au/roads/veh...ng_3Feb2006.pdf
In summary we can not increase tyre width by more than 30% over stock (OEM) or placard.
So Front can go from 225 out to max 292 (rounded to nearest avail size 285)
Rear can go from 245 out to 318 ( or 315 next avail size).
You can have any size Ø rim as long as you maintain aspect ratio and the overall diameter of the tyre is not more than 15mm larger than stock.
Also the tyres must be load rated to suit.
I suggest you print it out, highlight the parts pertinent and keep it with you and if he hassles you again, show him the error of his ways, then bend him over and shove it up his a**.
Hallelujah brudda.................
Edited by mosoto
They are illegal from a taste perspective anyway. lol
Says the guy who apparently has an R33. :D
19"s may look like shyte on an "R" designated Skyline, but on a V they are proportional and actually look good.
I think he was joking about the taste thing!!
As for the Cop... what a moron and if you got fined tell him you will see him in court.
Must be a bit green if he is telling you that and you should not always believe what you are told, especially by Police.
Also, never ever agree with them at all, never admit blame, just in case.
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
