Im getting to upgrade my stock injectors in my r33 gtst to nismo 555cc injectors and want to set them up so i can drive to the tuner to get tune. the stock injectors are 370cc so ive worked out the corecction to be .67, now with the latency diff i know its the new latency minus the old latency , but i dont know the latency for the nismo 555cc injectors but i know the stock ones are 0.528, so can anyone give me the vaules they have for upgrading to 555cc nismo in there rb25 or tell me the 555cc latency thanks
why is the latency 0.18? if the 555 is 0.71 and stock is 0.58
cant remember the latency for each but when i got my 555s i spent a while looking around for them and came to .18 correction. car ran perfectly first kick and drove on the same tune for 3-4 months with no troubles
just did a quick search and found this
http://www.skylinesaustralia.com/forums/In...smo+555+latency
yeah my mistake i was finking of stock injectors as .582 rather than .528 doing calcuations adds to .18 your right
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
