Hi guys
Just bought an ACA Universal O2 Sensor (3 wire), just wondering if this is the write one for a GTS-t? i'm pretty sure it is, just want to make sure.
Also, best way to fit? wack it straight in or is there somethin else i should do first?
Cheers
Cam
https://www.sau.com.au/forums/topic/289568-o2-sensor/
i cant tell you if it is the right one without seeing it or a part number. but the one i got to replace mine '32GTS-T was a direct fit for an EL falcon.
3 wires, one was shielded and the other 2 are positive and negative. the shielded wire goes to the ECU signal wire. it comes with the wrong plug but i picked up a 4 pin plug from supercheap and re wired it in. easy and neat so i wasnt joining wires together. works mint.
https://www.sau.com.au/forums/topic/289568-o2-sensor/#findComment-4849110
