So the story goes like this:
- Bought a rb25 GCG high flow, started boost creeping to like 20 psi +
- So then i was told i needed a OP6 Rear housing, chucked that on
- Now it holds a stable 18psi which is still too high for me
- its not the actuator as we've runned the car on the dyno with the wastegate open
Mods: ususal supporting stuff, 3' free flowing exhaust, decat pipe
It makes no sense as i've seen many people use the op6 rear housing without having such high boost
Hope to hear your opinons
Cheers
https://www.sau.com.au/forums/topic/289579-gcg-hiflow-over-boosting-to-18-psi/
think they make less boost on rb25's and more on rb20s ..could that be it ? Something to do with smaller engines making more boost easier...but I obviously don't know much about this stuff so I'll shutup.
I have an op6 and run .8 bar with out a problem.
What sort of dump pipe do you have, some ppl have problems with the wastegate flap hitting and not fully opening with a jjr dump pipe.
its the actuator and the actuator setup
it is the sole device for boost control
check or change the actuator
check the dump setup
check the boost controller (if you have one)
Wastegate flap is left open and hitting 18 psi
meaning it can't be actuator
the dump setup is fine, its 3 inch and flap does not hit
so if you remove the actuator from the the exhaust housing end you will still get 18psi at the plenum??
This is not right, this means that you wastegate flap is not opening, do you know 100% for sure that it was not welded up and the previous user was using an external gate instead?
if i was you i would pull the turbo off and check to make sure the flap is working fine, also how do you know that the flap isnt hitting the dump pipe, the only indicator that this may be happening is the exact problem you have.
i had this problem on my highflow. kept on going to 17 psi no matter what i did (even machined out wastegate) ended up being to rich a tune and to free flowing exhaust. had to put a restriction plate in my exhaust and when i was ready to run the higher boost level i took it out and got a retune and that fixed it run a flat 15 till i got a quieter exhaust, now it drops away at the end of the rev range
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
    • No, I don't remember the exact reasoning (was 20 years ago!) but the cops didn't end up supplying it to us either. Actually my mother went through a similar thing recently where she was hit when stationary, flustered and didn't get address (she got plate details, name, phone and insurance company, but not address). Person who hit her blocked her number and their insurance company (naturally) would not provide any details. Her insurance company also required her to pay the at fault premium because she did not have the address, cops did not help as it is a minor civil matter (they said their only course was if the other driver had left the scene of the accident without providing any details). She only ended up getting that refunded because they happened to be insured with Suncorp and she was with APIA so same company owners. For some reason the address is critical in insurance companies recovering money from the at fault party
    • If you're driving something like an R32 through to R34, no chance of meeting Euro4. Euro4 came out in 2006, and car manufacturers back then were complaining how hard it would be to meet those regulations. Not a chance a vehicle 10 years earlier is going to be compliant.
