just sat my 25/30 in my 32 and the intake manifold i've got wont fit with the clutch line where it is. The line on mine comes out of the bottom of the cylinder, if it come out the side would probably be fine( though couldn't hurt if the cylinder was slightly shorter). The picture on the just jap web site of the hcr32/cefiro one has the line coming out the side, can anyone tell me if it does? and what about the r33 cylinder? is it longer or shorter than the 32 and does the fluid line come out the side or bottom? would it fit the in 32 easily. will be running a 25 slave cylinder if that matters. Any info is much appreciated.
https://www.sau.com.au/forums/topic/289589-clutch-cylinder-for-32/
I've had similar problems, but used a different plenum (CPC).
S14 and R31(aus) have the line out the side.
Pic is of r31 relocated higher.
http://i223.photobucket.com/albums/dd81/30...ster-cleara.jpg
more pics here http://s223.photobucket.com/albums/dd81/30det/
R33 GTSt master cylinder is shorter than 32 and I think the line comes out the bottom (can check if needed).
I got one thinking my plenum wasn't going to clear (as matey had problems with his GREddy plenum) but my custom GTR plenum didn't foul.
thanks guys. I'll mesure up and see if the r33 20mm shorter will work( i've got a 25 box so will keep master, slave the same as factory). Also checked a mates s13 and was same cylinder diameter (5/8) was shorter than mine and the line was coming out the side.
  • 2 months later...
Thanks all ,i just did this works in a R31 aswell RB30DET with redrilled/elongated engine mount brackets holes drivers side by 15mm lower ,passenger bolt holes elongated by half a hole is all it would go.
I took turbo side engine mount bracket (4 bolts off) then plenum Greddy copy just fitted past clutch master cylinder from r33.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
