Blitz Bov, old model, comes with mount for rb20,rb25 in stock position, and plug for plumb back hose..
$210
Davies Craig Electric Water Pump , brand new never installed $180
Bride Brix Seat - with r32,r33 and a31 rails.. could be modified for silvias...
$580
STOCK R32 STUFF -
dump pipe(with gasket) - $30
castor rods - $20
Clutch Fan - $10
RB20DET AFM - $90
cheers
email - [email protected]
https://www.sau.com.au/forums/topic/28959-parts-for-sale/
  • 1 month later...
