1995 R33 Gtst Type M With Forged Rb25/30
1995 R33 GTST Type M with RB25/30 $16600
Location - Kallangur, QLD.
Looking to sell my pride and joy due to financial difficulty. Elite Racing Developments built the engine and installed the suspension. Engine has done about 14000km's since rebuild. Built for response and street driving. Positive pressure at 2000rpm and full boost at 3000. The car achieved 344hp on a low reading dyno. It has a relatively small turbo but has everything you need to install a larger turbo if you're after big power. All tuning done by Matt Spry at Pits.
With the suspension and torque from the RB30 its a dream to drive on the road. It'll make a great trackday car too.
To view pictures, have a look at my Carsales Ad. http://www.carsales.com.au/all-cars/privat...9&silo=1011
Engine
-RB30 bottom end, RB25 head with VVT
-VG30 Highflow turbo by Precision Turbochargers
-Apexi PowerFC
-Blitz SBC ID3 boost controller
-JE racing pistons
-JE rings
-Spool rods
-Head street ported and fully serviced, new valve stems, valve seats recut, head crack tested and decked
-Crank crack tested, re-dowled, balanced and polished
-Block crack tested, bored, honed and decked
-N1 oil pump
-GMB water pump
-Custom 8 Litre racing sump by Predator Motorsports
-External oil return from head to sump
-Smaller oil restrictors in head
-15 row oil cooler with remote filter
-Nismo 740cc injectors
-Nismo fuel pressure regulator
-Nismo fuel pump
-Excedy brass button clutch
-Z32 Air flow meter
-Iridium spark plugs
-Hybrid style front mount intercooler
-Apexi power intake pod filter
-Custom aluminium laser cut coil pack cover
-Greddy catch can
-Stainless intake pipe
-Radiator air guide
-Mod plate for engine and FMIC
Exhaust
-3 inch system
-Split dump pipe
-Metalcat highflow cat
Suspension
-Bilstein shocks front and rear
-Whiteline springs front and rear
-Whiteline adjustable swaybars front and rear
-Whiteline front caster kit
-Whiteline camber kit front and rear
-Whiteline subframe alignment bushes
-Whiteline dust covers and bump stops
-Whiteline front strut brace (not fitted)
Interior
-PowerFC hand controller
-HKS turbo timer
-Mongoose M80 alarm with shock, tilt and glass break sensor. Remote boot release.
-JVC Mp3 head unit
-JVC 4 channel amp
-White door inserts
-White handbrake and gearstick boots
-Boost gauge
Exterior
-Factory sunroof
-18 inch mags
-GTR front bar
-Nismo clear side indicators
-Painted front brake callipers
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
