I'll be down taking photos/vids of a mate in a red TME Evo 6 and a Purple VR4 Galant.
If I spot your car I'll try grab a few of you too.
Anybody else going down, let me know and I'll try to squeeze you guys in too.
lovely night,albeit a bit cold. packed to the rafters with cars. only managed a 13.466 @ 175 km/h and 2.3** 60fters. either bogged on the line or axle tramped. at least the top end speed shows that the ol girl is good for a mid to high 12 with a good start.
Guest
