I'm thinking I may go for a bit more oomph (R34GTT).
I dont want much and reckon about 190 to 220Kw ATRW will be fine and I'd like to see it by around 4500rpm so I'll be after something that spools up smartly.
Has anyone any idea as to what turbo I'd be looking for ?
I'm not bothered about huge top end at 6500/7000rpm , it's a streeter and I'm not bothered about shit I won't/can't use.
I've read good results can be obtained fron Hi flowing the stocky but I realy aint got a clue what I'm looking for so any advice is welcome.
I'm also not interested in flinging a front mount on it, closer to stock I can be whilst getting what I'm after the more I like it.
The car has an exhaust system that could cope with anything I and ten others could throw at it so the only other thing would be what engine management ? I was wondering if an SAFC might be enough ? or a reflash but where from ? I've read shitloads of stuff and am none the wiser.
:D
https://www.sau.com.au/forums/topic/289645-what-turbo/
Thanks for the replys guys reality check is a real 170 to 180 ATRW would be fine but I'd like to achieve that without pulling 6000+rpm to do it, as this is my first Skyline I'm a bit at sea with what turbo will do what.
I've had a couple of 00 WRXs before and with those I'd just slap on a VF28 a 3" turbo back zorst and an ECUtec tune and and orf I'd go with safe as houses engine and around a quick 180Kws AAF.
I'm sure theres a similar formula for the R34 I just can't seem to find it, I'm not after monster top end power just a quick street spool, the stock propeller seems to start its run at around 3500rpm so I'm guessing I'd be looking for something that starts aroung 2800/3000rpm.
I'm not keen on throwing away the factory ECU considering what I'm after so a flashtune that reverts to stock as a 1st default would be my preference, if such a thing exists ?
Don't get me wrong the car goes very nicely I'm just being a bit of an Oliver.
https://www.sau.com.au/forums/topic/289645-what-turbo/#findComment-4850041
:P
i'd get a tune with aftermarket management done as that sounds pretty high (i would also check for boost leaks and that the wastegate actuator isn't fouling). although the turbo is slightly smaller on the r33, i was making 14psi by around 2800rpm in my r33 with stock turbo.
the problem is that you are wanting 2 different things which don't really go together. power and response usually require 2 different types of turbo. power requires a bigger turbo, but you lose response. response requires a smaller turbo but you lose power. there are turbo's that will give you the power you are after and the response, however they are a bit of a waste, and going to set you back a bit of coin. to run them safely you would an aftermarket ecu or something like a nistune, bigger injectors, fuel pump, possibly a bigger afm. all up the setup including the turbo is going to set you back quite a few thousand. it will require running high boost levels which will shorten engine life and increase your fuel bill.
what mods are you currently running? there is no point in telling you to upgrade the turbo if you are currently running plenty of stock parts as you haven't even gotten all of the performance out of the stock car yet. so answer the following questions....
what boost are you running?
what exhaust do you have?
i think that is about it. you said above you aren't interested in putting a front mount on. unless you get an aftermarket side mount, you are going to have to as the stock cooler is going to be getting close to it's limit for what you are looking for. it will manage it, but i would be looking at upgrading, especially coming into summer.
personally, my suggestion for what you want is to get a nistune (provided it is available for your ECU), front mount, full turbo back exhaust if you don't already have it and wind the boost up to 12psi. that should see your goal. or be very close to it and you have saved yourself a few thousand dollars of overkill
https://www.sau.com.au/forums/topic/289645-what-turbo/#findComment-4851841
:P Thanks for that, where would I find Nistune ? is that the one with an additional/ replacement motherboard ? If it's the Nissan equivalant of ECUtech that could be just the thing I'm after, I'll try a google but any link you could post would be much appreciated.
I'm running stock boost, I haven't put a gauge on it and there appear to be no leaks so whatever OE is, it is, the car ain't what you'd call slow by any stretch of the imagination it could just be a tad sharper if you know what I mean.
The exhaust is a 3" jap dump, a new highflow 3" cat, a 3.5" cat back to a 3.5" jap mid muffler and a new 3.5" Varex rear muffler set to 60% apperture, the muffler also has an internal 1" permanent bypass, it's disgustingly street legal even when at 100% apperture.
I didn't know you could get aftermarket sidemounts do you know who does them ?
I'm a bit off frontmounts as I always associate them with lag (rightly or wrongly) and the kind of power levels I'm just not after + I think it would nean a plenum change and all the turtling around that goes along with that.
Thanks again,
Al.
Edited by BASHO
https://www.sau.com.au/forums/topic/289645-what-turbo/#findComment-4851966
I'd say a highflow would be a cheap upgrade for your power range. and this http://www.skylinesaustralia.com/forums/Po...ad-t210097.html for your remapping.
Thanks mate, I'd do this in a heartbeat if I were in Sydney , but unfortunately I'm in Surfers. :P
https://www.sau.com.au/forums/topic/289645-what-turbo/#findComment-4852024
http://www.nistune.com/
and since you are running stock boost, get yourself a cheap manual boost controller (one of these will do fine- it's what i used) and wind the boost up to around 11 or 12psi (obviously need to get a boost gauge first, but even a $50 drift one will do the job). you will notice a big increase in performance as you will probably be gaining at least 30 or 40kw. and you should be able to run that boost on the stock ecu.
https://www.sau.com.au/forums/topic/289645-what-turbo/#findComment-4852102
Ok, I got a stock turbo...running a Greddy Emanage, exhaust, electronic boost controller, Pod and front mount then got it tuned...making over 230 KW's easily so you shouldn't have much trouble getting this from your stock turbo...
https://www.sau.com.au/forums/topic/289645-what-turbo/#findComment-4852507
very happy dyno
get a frontmount, with a stock turbo and a manual boost controller you should see 12-13psi by 2500-2700 under load. hardly "laggy"
dont need to change plenum to run a fmic
https://www.sau.com.au/forums/topic/289645-what-turbo/#findComment-4852805
the plenum is the least of your worries.
FMIC are always associated with lag for some reason, maybe in the 1980's with dinosaur technology it was the case...
i put a blitz FMIC on my silvia and didnt notice any extra lag, but heaps more power.... the miniscule lag is far outweighed when you make 20-30kw more.
https://www.sau.com.au/forums/topic/289645-what-turbo/#findComment-4852811
230... not likely
https://www.sau.com.au/forums/topic/289645-what-turbo/#findComment-4852907
spunky munky never said what boost he is running. so unless you know what boost he is running you can't say that it is a happy dyno. i know a few people with r33's getting up around (and just over) 220kw on the stock turbo (different dynos in different states), and it is smaller than the r34 turbo.
https://www.sau.com.au/forums/topic/289645-what-turbo/#findComment-4853699
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
    • No, I don't remember the exact reasoning (was 20 years ago!) but the cops didn't end up supplying it to us either. Actually my mother went through a similar thing recently where she was hit when stationary, flustered and didn't get address (she got plate details, name, phone and insurance company, but not address). Person who hit her blocked her number and their insurance company (naturally) would not provide any details. Her insurance company also required her to pay the at fault premium because she did not have the address, cops did not help as it is a minor civil matter (they said their only course was if the other driver had left the scene of the accident without providing any details). She only ended up getting that refunded because they happened to be insured with Suncorp and she was with APIA so same company owners. For some reason the address is critical in insurance companies recovering money from the at fault party
    • If you're driving something like an R32 through to R34, no chance of meeting Euro4. Euro4 came out in 2006, and car manufacturers back then were complaining how hard it would be to meet those regulations. Not a chance a vehicle 10 years earlier is going to be compliant.
    • I presume it would take more than just slapping a big modern catalyst on the exhaust? It's interesting though, looking at the old sales brochures and listings it does not mention anything about emissions. No one cared.
    • Yeh nice, looks like their part of keep it reet? Will have to swing past. I'd much prefer someone actually look at my car and custom make a part, then get a generic part online and hope it works.
