I looked in to this when i first bought my 34GT . From memory, simply put - by replacing your exhaust side cam gear with the GTT or aftermarket one, you can acheive a good power gain. Not 100% on the settings as to retard or advance it, depends on the driver's preferences really. Look forward to hearing from more people's experiences...I never went ahead with mine, still got the cam gear sitting on my desk!
They should be fine. Again, to retain your VCT, you should leave the intake cam gear untouched and replace only the exhaust side. I havn't had enough experience with them to recommend anything, but I'm sure there's someone in the N/A section who can clarify.
Tomei pon cams to suit the neo head will drop into the NA neo head. These cams are designed to retain VCT so you only put an adjustable gear on the exhaust side for tuning.
The stock cams between the turbo and na neo heads have the same duration and lift (according to tomei), so if you mean switching to "turbo cams", make sure they are aftermarket neo cams.
They'll fit but they are less aggressive than the NA cams so very little point.
Usually the reverse is done, people usually fit the NA cams into turbo motor
that is what i thought. i know that guys with turbo SR20s often put in the NA cams as a cheap, basic upgrade
    • The door and bonnet gaps look very tight for such cheap models 👍
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
