g'day,
i was thinking about buying a set of thease for my r32 gtr.
http://cgi.ebay.com/ebaymotors/Garrett-GT2...sQ5fAccessories
my current turbos are gt2530 from what i was told by the car dealer i purchased the car off (very dodgy bloke/..)
i want to get the block bored to around 2.8L or even 3L, does anyone know if it could go that far ?
the only reason i want to bore the block is because the turbos will lag like mad rite ?
thease are the biggest twin turbo setup i can find..
i basically want to achieve around 600kw for my track car..
if anyone has had any experiance with thease turbos, or anyone that has a better opinion on what should do would be much appreciated.
https://www.sau.com.au/forums/topic/289665-new-turbos/
I have not had any experience ( im poor i only own a gtst) but from what i have seen to get 2.8l you use a stroker kit and for 3.0l you use an rb30 bottom end, im guessing very little inside your motor will be left standard to achieve a reliable 600awkw so 3g+ on turbo's will be the least of your expense.
https://www.sau.com.au/forums/topic/289665-new-turbos/#findComment-4849192
rb 26/30 (obviously seriously built)
gtrs turbos or something similar/bigger
a f**kload of boost
should definately see u over the 500kw + mark buddy
i wouldnt want to know what the bill would be like though lol
https://www.sau.com.au/forums/topic/289665-new-turbos/#findComment-4849194
600rwkw or 600kw @ the fly?
Either way, it sounds like you need to do more reading mate.
If you think you can bore a GTR block out to 2800cc total you're already showing a little lack of knowledge... let alone needing 600kw in a track car.
Also turbos having mad lag, another giveaway perhaps more homework needed.
What is the budget?
What are the current mods?
What are your current lap times?
What lap times are you after?
https://www.sau.com.au/forums/topic/289665-new-turbos/#findComment-4849242
g'day,
Hmm that horsepower level will cost around the $50K minimum. I would suggest a more realistic power level is what is required.
https://www.sau.com.au/forums/topic/289665-new-turbos/#findComment-4849247
Those turbos are tiny for the power you want, A/R .64? Please.
For 600kw at the wheels you're looking at some serious horsepower, and a built engine, you'll have to fortify the top end with various JUN / Tomei / Whatever parts and maybe even the bottom end depending on what you're going to be using all that power for. Remember you have an RB26 not a 2JZ lol.
Secondly I wouldn't buy my turbos off ebay, I'd buy from a registered Garret dealer where you have things like warranty.
If I wanted 600awkw from an RB26 I'd get 2 GT35R's with .82 rear housings from a registered Garret dealer, like Horsepower In A Box.
Then I'd find a workshop willing to tune such an animal and an ECU that would be reliable at that level of power, you're going to need a custom fuel setup, at least a 2.5L surge using something like a Carter Gold lifter pump and 2 x Bosch 044's with return lines.
I wouldn't bother trying to bore out your engine to a massive 2.8L, is that even possible? Instead you could purchase a stroker kit.
This is all going to cost big dollars, I wouldn't undergo this project unless you had at least $25k and a workshop that you could trust.
https://www.sau.com.au/forums/topic/289665-new-turbos/#findComment-4849870
that is stupid. 35Rs will flow over 400kw atw EACH. the lag on that sort of setup would be stupendous.
HKS GT-RS's will make the power you are talking about. Lag will be an issue and will require a lot of money & time to try and negate. If you don't know what your doing and havent done much track work before (assuming this based on your post) then start off small and work your way up. You will lap faster in a responsive 400hp gtr than in your 700-800hp setup with lag and traction issues.
https://www.sau.com.au/forums/topic/289665-new-turbos/#findComment-4850177
well 600kw @ the fly is still what, 500rwkw give/take?
Well considering he said 500-600kw i would be thinking 400-500rwkw which is "achievable" more so than 600rwkw.
If you wanted something "fairly responsive" (hell i dont call anything with that kind of power on a RB responsive but whatever) with that kind of power i'd be looking at something along the lines of a 30/26 with twin GT-RS's.
But as has been said, why so much power? I'd be looking at lower power levels but be concentrating on response.
https://www.sau.com.au/forums/topic/289665-new-turbos/#findComment-4850502
hioctane have demonstrated that a 26/30 with 2860-5's makes for a very quick combo.
with a hollinger...
and special diffs...
and an endless budget...
realisticly you should budget atleast 70k to do it properly with a box and diffs etc and thats not including labour from a workshop
https://www.sau.com.au/forums/topic/289665-new-turbos/#findComment-4850822
It is not stupid it's a solution that I know of several drag cars running 800-900rwhp at only 20psi.
Remember the OP never stated what he wanted so much power for.
Does he want a responsive track car? a dyno queen? highway warrior? something that runs 10's?
More information needs to be posted.
All we receieved was an ebay link and an "I want this much power"
How long is a piece of string? etc...
https://www.sau.com.au/forums/topic/289665-new-turbos/#findComment-4851516
I think 600Kw at the crank let alone the wheels is an unrealistic goal to have in the first place .
If you want to have a usable rev range with that sort of output I think even 3 litres (200 odd Cu ?) is a bit lacking .
Having telephone number outputs is one thing and being able to do something useful with it , let alone affording it , is another .
I don't think 600 hp at the crankshaft is unrealistic in a track RB30 but I don't think it'd be a nice drive on the street .
A while back it was mentioned to me by possibly SK that RB30's can be stroked usefully to about 3.2-3.3L and compared to some of the zillion dollar mods people do at times it may not be as expensive ($/Kw) as many think .
Std bore/stroke RB26's revved to 11 may be one thing but the budget must be horrendous .
IMO need more cubes , do any of the later 3.5L V6's have any hope of going into an R32/3/4 ?
A .
https://www.sau.com.au/forums/topic/289665-new-turbos/#findComment-4851637
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
