beRwick_GTRage Posted September 27, 2009 Share Posted September 27, 2009 How do i remove the intake cam off an rb25neo series 2? thats what it looks like cant undo the middle bolt without the pulley turning. Link to comment https://www.sau.com.au/forums/topic/289666-how-do-i-remove-the-intake-cam-pulley-on-an-rb25neo/ Share on other sites More sharing options...
scotty nm35 Posted September 27, 2009 Share Posted September 27, 2009 How do i remove the intake cam off an rb25neo series 2?thats what it looks like cant undo the middle bolt without the pulley turning. You couldnt have have loosened it before you took the belt off? Or use the belt to hold it? Link to comment https://www.sau.com.au/forums/topic/289666-how-do-i-remove-the-intake-cam-pulley-on-an-rb25neo/#findComment-4849281 Share on other sites More sharing options...
JOHNNNY Posted September 27, 2009 Share Posted September 27, 2009 your best bet mate would be to use a rattle gun on the bolt , but you will need to hold the pully some how either re-fit the belt and then remove it. or if you think you can hold it wrap a rag around the pully and get one person to hold it and another to work the rattle gun you should get it BUT IT WILL BE VERY TIGHT and may also have loctite on the thead too. you may need to use an extension on the rattle gun to clear the radiator ! good luck mate Link to comment https://www.sau.com.au/forums/topic/289666-how-do-i-remove-the-intake-cam-pulley-on-an-rb25neo/#findComment-4849682 Share on other sites More sharing options...
scotty nm35 Posted September 27, 2009 Share Posted September 27, 2009 Rattle gun? Only if all else fails. Try refitting old belt and jam a piece of timber dowel between the pulley and belt in the pinch point as you turn the cap screw, using a big breaker. 243 Loctite the bolt back in when you reinstall. Are you doing a pulley or cam upgrade? Link to comment https://www.sau.com.au/forums/topic/289666-how-do-i-remove-the-intake-cam-pulley-on-an-rb25neo/#findComment-4849724 Share on other sites More sharing options...
darrinspencer Posted September 27, 2009 Share Posted September 27, 2009 When I did mine, I removed the inlet cam cover. The camshaft has a hex shape to be able to hold the shaft from turning with a big shifter. Not too hard to do. Link to comment https://www.sau.com.au/forums/topic/289666-how-do-i-remove-the-intake-cam-pulley-on-an-rb25neo/#findComment-4849947 Share on other sites More sharing options...
pyro-ns Posted September 28, 2009 Share Posted September 28, 2009 When I did mine, I removed the inlet cam cover. The camshaft has a hex shape to be able to hold the shaft from turning with a big shifter. Not too hard to do. ^^^ this is what i'd be doing. to the best of my knowledge, the tolerances are small enough that if you rotate the cam without rotating the crank, you run the risk of hitting your pistons with your valves. Link to comment https://www.sau.com.au/forums/topic/289666-how-do-i-remove-the-intake-cam-pulley-on-an-rb25neo/#findComment-4850398 Share on other sites More sharing options...
lachlanw Posted September 28, 2009 Share Posted September 28, 2009 the answer to your question is undo the bolt in the middle of it . Link to comment https://www.sau.com.au/forums/topic/289666-how-do-i-remove-the-intake-cam-pulley-on-an-rb25neo/#findComment-4850645 Share on other sites More sharing options...
