lol update us in 10 years :D
yeah this is how Stacey was..."yeah im buying a GTR" "yeah more power would be great" "Im going to race it" "I won my 1st event" "I won a National title" "How good am i" "I love the car"
to..."I hate that damn car" "Lets sell it and buy a new kitchen" "When are you going to top spending money on that bloody thing" "Your going racing in sydney the whole weekend" etc...
time is your enemy my friend.
  • Replies 181
well no more photos but i mounted the power steering cooler and oil cooler yesterday as well as finished the internal wiring hopefully have it to RE Custom next week to finally be started and get a run in tune
yep people told me it would be a good thing to do!!!!
does not cost much and any thing to help me is a good thing LOL!!!
and when you say try the old rack what are you talking about?????
  • 3 weeks later...
Speaking to your old man I thought you were ditching the power steering by removing the guts ot of the rack. Less weight.
in the end i got a brand new rack so i thought i would use it.
well today it started helllllllll yeahhhhhhhhhhhh!!!!!!!!!!!!!
http://www.facebook.com/video/video.php?v=...7447&ref=mf
  • 2 months later...
ok guys have not done any updates for a while so here we go
first we finished the plumbing and sorted out the wireing. well sort of so we thought.
first the car would just die after a short while on idle so we thought we have a fule pump wireing problem, was not that.
next we found out the ignitors were dieing fast went through 5 befor we found out that the haltech need to run the relay that goes to the coils and not off our switch we had!!!
no its all sorted and i have finaly had a start tune!!!!!!!!
we made 325 rwkw on semis at 16 psi
and here is the first movie of me driving the car for the first time
so happy now to sort out the last little bits and put it all back together and in show condition.
Well done guys, look forward to seeing it out there.
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
