well worked on the car on staterday and took the fuel system out due to a small leek from the tank LOL!!! only a pin hole under presuser but all rewelded and tested. decided to check the fuel filters and found only a small amount of crap so was very happy. but when expecting the holly lift pump i found it was leaking from the top seal so now im going to take it back and get it checked NFH!!!!.
or well by next week should be all back together and time for start the tidy of the wireing and the 4wd system!!!
  • Replies 181
well the fun has started!!!!!!!!!!!!!!!!!!!
we cleaned the tank and got it all ready to put back together but noticed the holyee lift pump had a bit of fuel running from the back where a small hole is to tell you that the nylon sleave has shit it self. well it has only after around 4 to 5 hours of run time NOT F%^KING happy the pump costs a bit and now have to replace.
so with that now on the cards i have come to the conclusion that i will now run an intank low presure pump and feed the surge tank that way.
photos to come
  • 2 months later...
Gday Scott, and John, who as it turns out IS on SAU!!
In a word... Gobsmacked!
As others have said, awesome build with a result that is amazing.
The best part is that you guys have been able to share this project father/son and even got Claire in on it too!
I can remember watching those cars at Bathurst back in the early 90's (before the pack of arseholes speech) and they are the reason I now have a 32 GTR myself.
You guys are gonna fit in very well with the bunch we have going to Tokyo! See you guys soon...
  • 1 month later...
  • 2 months later...
  • 1 month later...
hey guys just a few more photos of the car
well this was an honer to have the car at the TOP GEAR MELBOURNE show a mounth ago with MOTIVE DVD big thanks to Ash and Andrew for using the car
and this little one is of our car coming out of the transporter at the shannons classic
  • 1 month later...
  • 4 months later...
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
