hey guys i read around a bit in these forums, people say the headlights on a 06 will fit 03 models, so im just wondering will the back lights also fit? Also what would be the price be for a set of 06 headlights (labour not included) and what the cost would be to place them in by a pro?
anyone got any direct comparison pics of 03 and 06 headlights and back lights they could post up, i've googled but no dice.
https://www.sau.com.au/forums/topic/289683-headlights-back-lights-06-on-03/
06 headlights have projector lenses for the main beam. They are slightly rearranged, the vertical strip doesnt light up.
Pictures of my car:
2003 lights -
2006 lights -
Very nice upgrade but they are NOT cheap. Expect about $1,000.
Tail lights on the 06 model are, well, not flat. Check out this one on carsales.
http://www.carsales.com.au/Tig/UI/PagePopu...mp;tabID=304744
i like the vertical light up on the 03 though the look of the 06 lights overall look better but i dont think id waste my 1k on lights though...just me though others might and probably have.
ps awesome looking V there - love the wheels clean cut.
Thanks mate.
In person, the 2006 headlights look a lot better than the 2003 ones. I've had lots of comments about the car looking more modern with them.
But anyway, the main point of them is for the projector lenses so that you can use HIDs properly.. you can always do a retrofit like 350gtfrank
Also the tail lights on the 06 have a boot release button. Not sure if this can be connected up to 03 easily though?
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
