^^ Agreed with JonnoHR31
I was on my old Ps and got a letter in the mail detailing the new system, and a pair of new plates from the DPI. Between my own cars and work vehicles I was buying new sets of plates every couple of months anyway. The new color scheme was available almost straight away from service stations / auto stores. Dunno how you managed to go for over a year without knowing about it, especially with all the other cars on the road with them.
Who can you blame speeding on then? :D
Soccer mums in 4x4s?
"Officer, I felt my life was in danger as I was going to get crushed by those crazy b*tches in single lane roads, so I speed to shake them off".
I have white P plates with the P written in RED.
James, unfortunately the police officer was right - the correct P-Plates have a red background with the "P" written in white, or a green background with the "P" written in white, hence the Red/Green P-Plates.
So in effect you weren't displaying the correct P-Plates, however that was pretty darn harsh of him to fine you for that.
haha i was gonna say how can you afford a 33 gtr :( well i get my red's on thursday so thanks for letting me know:) did you lose any demerit points?
No you don't loose demerit points at all even if you don't have any P-Plates showing...i got done 4 times for no P-Plates oops :D
Guest
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
