Hi guys,
Trying to locate a wiring diagram for the Series 2 Stagea that also displays what colour the wires are that come from the ECU. I have the pinout diagram which claims its for both Stagea and R34, but they plug is slightly different enough to give me doubts. I need to know the correct colours of pinouts 5, 23 and 54. I have a few gauges to install.
I only have an R34 pinout diagram which claims to be for the Stagea also. But it appears my S2 stagea is slightly different, ie pinout 22 and 23 neighbour each other without a separator, whereas in the pinout diagram it shows they are separated.
Help please, asap :laugh:
https://www.sau.com.au/forums/topic/289687-stagea-wiring-diagram/
Hi guys,
No doubt you've squirrelled through this lot? In DIY Stagea ecu blurb. Plenty of names to contact if info not on pdf.
Cheers GW
Quote < Hi guys as Darrin said there are at least 3 pin outs for series 1 W34 stageas. More details including how to identify by date and model code on ECU are in this thread:
Looks like the earliest ones are a very close match to R34 GTT. >Unquote.
http://www.skylinesaustralia.com/forums/R3...S1-t205298.html
PS: Not that this means anything but I have not seen any color coded diagrams, only numbered. Best thing to do in that case is bell out points of interest, 5, 23, 54. A/T input sig, Knock sensor, un-assigned. If you are looking for the following, on another diag I have; 38/Throttle sensor sig, 27/mass air flow sig, 7/tacho sensor sig. Or (your diag most likely.....R34) 5/Tacho drive sig, 23/Throttle position sensor sig, 54/mass airflow sensor sig.
PPS: My R34 pinout diag shows minor divider between 22/23 also.
Edited by 260tech
Yeah its that minor divider that is throwing me out (between 22/33 and not 21/22 as my Stagea is showing). Want to ensure that what I think are 5, 23 and 54 are indeed 5, 23 and 54 from the R34 pinouts.
My S1 Stagea pinout shows
pin 5 as tachometer Drive signal W/B
pin 23 TPS signal R/L
pin 54 MAF signal O/L
no idea what L stands for
I'm sure S2 are different. Should be (from what I can ascertain):
pin 5 is yellow/black
pin 23 is green/black
pin 54 is grey/blue
pin 5 as tachometer activation signal
pin 23 Throttle sensor signal
pin 37 Throttle opening signal
pin 54 airflow meter signal
pin 55 airflow meter earth
The problem is that the S2 pinout diagrams I have downloaded are claimed to be similar to the R34. But they're slightly different. The S2 pinouts are slightly different to the R34 pinouts and therefore I need to ensure the coloured wires for 5, 23 and 54 are indeed what I'm going to tap into! But nothing, NOTHING has the colours labelled. And everytime I look up a S2 Stagea wiring diagram, they give me an R34 diagram. Which is not the same.
Well I can't believe it.
I cannot source from anywhere a correct ECU pinout diagram for the series 2 Stagea. All references lead to the R34 pinouts which is incorrect.
Nissan themselves have nothing???
Not going to bother if I can't be 100%.
Trying to give my 2 cents...
check this 2 treads...one shows a fast and the other shows the pics of 2 Ecu s (one is the same number as yours)maybe contacting those members you can get any idea...
http://www.skylinesaustralia.com/forums/Pi...0&p=4785101
http://www.skylinesaustralia.com/forums/St...rs-t285701.html
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
