Hey peeps,
RB26 timing belt cover in mint condition,
Hardly ever been used, Blue metallic
Paid top dollar for part and paint
Upgraded to clear so not needed
$45..
Standard factory GTR ECU
Original ecu, Dont need it coz i got a Power FC
Just want it gone its collecting dust
$70..
Plenty of clear pics, Will post anywhere @ buyers cost
PM me for more details.. Cheers
Edited by jimmi032
https://www.sau.com.au/forums/topic/289688-rb26-ecu-timing-belt-cover/
