Good Place To Buy Kits In Adelaide For A Reasonable Price
Vivagarage.
www.yellowpages.com.au
+1
But you'll need to fit and paint it yourself ... or take it to a shop to do for you.
+1
unless your a good fibreglasser, i suggest taking it to a pro to have it fitted properly.
Mine fitted up no probs. Just take your time fitting it and get it right first time. Be impatient and you'll f**k it up. Remove when fits right, then paint.
www.vivagarage.com.au
brought my Front lip from there for my r33 ( TYPE BL ) looks nice if it was fitted, but still waiting for a quote from a guy that vivagarge told me to call afew weeks ago ............
Speak to Tarik at racespec. top quality and great price.
racespec.com.au
:P
unrivaled quality and service with a product that cant be beat.
seriously, 5 minutes of searching completely voids your opinion.
imo, kits are stupid. but if you insist on having one, import a *slightly* more expensive, but properly manufactured and well fitting kit from j.
If you seriously want quality then there is only really Bodyform for perfect fitment and consistancy with quality. You pay a little more but its worth it.
I have a R33 2D Coupe 400R Rear Bar and Side skirts from them I am selling in Adelaide if you are interested PM me
racespec.com.au
I highly reccomend racespec +1 great Tarek is a gud mate will definately help you out if i were you id go in there personally and have a chat to him becoz he hasnt got many bodykits on the website and he culd possibly find em even if he dnt stock them :)
I highly reccomend racespec +1 great Tarek is a gud mate will definately help you out if i were you id go in there personally and have a chat to him becoz he hasnt got many bodykits on the website and he culd possibly find em even if he dnt stock them :P
see that part in bold?
thatd be why youre saying the part in italics.
and before im attacked for it, i know people that have paid for kits and waited months with little to no communication before theyve received kits that have been so thin theyre almost see through and have need to be cut, extended, and shut to fit.
so my opinion remains, if youre going to buy a kit, dont bother with the cheap shit that most joints sell, buy genuine through an importer like streeter.
Edited by scandyflick
A mate of mine is also a good mates with Tarek but when he wanted a front bar from him the quality was shit. You could lay the front bar on the ground and see it wasnt straight. Was shocking.
+1 for Bodyform tho, awesome kits and good quality. Or get one from Jap.
Fair enough but not like he wuld purposly give him a bad kit im sure if he went bak he wulda swapped it for anotha one with no probz. but i undastand were ur comin from yes he is ma mate but i know plenty of people who have bought kits and other parts of him includin maself and were fine everyone has their bad days i guess.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
