Guest RedLineGTR
http://www.uniqueautosports.com.au/
Have alot of them for sale otherwise a couple of bodykit shops in every state usually have them. I assume your in Japan??? you should have a shitload over there to choose from..
Some nice pics to have a look at.
http://www.uniqueautosports.com.au/priceli...carbonfibre.htm
Most of the carbon fibre bonnets in aus arnt the real deal. A Genuine fibre glass bonnet cost into the two thousands.
https://www.sau.com.au/forums/topic/28974-carbon-bonnet/#findComment-595935
yeah iam currently in Japan... ill mention my current situation... friend wants me to buy him a carbon fibre bonnet.. and honestly.. i cbf organizing shipment of a bonnet back to australia. ( especially when you need to put it into somebodys container.. blah blah ) So iam trying to find a good bonnet in Aussie and tell him to buy it from them !
https://www.sau.com.au/forums/topic/28974-carbon-bonnet/#findComment-596109
INASNT i wouldnt mind getting some people together if there is interest would work out cheaper. If it is a good price lets say we get like 5-6people together i would be keen.
Sentric dancer so are u from japan???
How much lighter are they than the stocker?
I am actually up in qld at the moment so i could bring them back, but how...
https://www.sau.com.au/forums/topic/28974-carbon-bonnet/#findComment-596121
http://www.skylinesaustralia.com/forums/sh...eight+reduction
Stock R33 bonnet = 18kg
UAS c/f bonnet = 10kg
Thats not true c/f either, so for alittle bit more in Japan you could get a real c/f bonnet which would probably be :D
https://www.sau.com.au/forums/topic/28974-carbon-bonnet/#findComment-596204
We have already established (above) that the weight is 10kg vs 18kg.
If you are buying it purely for weight saving then don't bother ($1,100 for 8kg ur kidding right.. go on a diet for a week). But if you are buying it for the looks or extra cooling vents then they are fantastic.
https://www.sau.com.au/forums/topic/28974-carbon-bonnet/#findComment-596623
one word.... altho it sounds like 2 depending on how u say it...
NENGUN
get a REAL carbon bonnet not a crappy glass one with carbon on top....
SHIFT baby!! and it doesnt look as ricey with 5 different vents all over the place which u wont need...
https://www.sau.com.au/forums/topic/28974-carbon-bonnet/#findComment-596818
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
