define 'full' ... That shit's heavy and will add a lot of unnecessary weight if you put it in the roof and all the other stuff. Just get the doors and boot (if putting in a sub) dynamatted or do it yourself. Shit's expensive too, not just heavy. Before, after doesn't matter ..whenever it's cheaper (probably during stereo install)
i pay $40each full sheet and yes i would be installing the dynamat before installing speakers as u want the dynamat between the speaker and the door to stop them vibrating against each other, there is other option like liquid deadener and other cheaper copies of dynamat but none will be as easy to install nor will they work as good thats what i think anyway.
Edited by mark660
Im in the process of doing the second layer of dynomat and some other tricks to silence the car inside(For SPL competitions and my sanity on adelaide ruts)..my GTT had a serious case of rattles in the sunroof area even with the radio off.lol
there are many Dynamat copies and some work just as good if not better when you consider price. but dynamat has great quality
anything is better then nothing???
iirc dynamat recommend doors first, then boot, then the floor. i've had just my doors done (outer and inner skin) and it's made a significant difference.
oh and don't worry about the excess weight, unless you are going to race the thing.
in which case you wouldn't be wanting a big doof doof stereo to start with, LOL
Try Marty at FHRX, $40/sheet is expensive! I remember paying about $25/sheet roughly.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
