Did they cover it under warranty? and if so how long was the turn around from taking it off to putting it back on?
I dont mean to take over this thread, just a question which is relative to some posts in here...
What do you believe is the best way to bed the rings with a fresh motor? My new 30/25 combo will be ready soon, and I was told by a very reputable tuner/builder to start the engine from cold, and let it idle, every min for 10 mins bring the revs up to about 2500rpm for a few seconds (repeat this). Then turn engine off, let it cool completely, and then do this again 3 times a day for a couple of days. Then take it off to get its run in tune.
What do you think? I hear ACL bearings are very particular and require babying within the first few hundred km's
And as asked, what is the best oil to use on run in and once the first 1500km's have been brought up...
  • Replies 46
my car was started and run for 30 seconds to make sure it started, idled properly and oil pressure came up. then it went off to a dyno to be run in and tuned. (both occured on the same day doing 3 oil and filter changes to make sure there wasnt excessive metal in the oil) i believe it is now running synthetic oil after only about 45 pulls on the dyno + loading the engine up for the run in.
  • 5 months later...
Completely forgot about this thread.
Replaced the turbo a few months ago and the car blows zero smoke now. Funny that GCG denied it was their fault and said it was the tune of the car that destroyed it from overheating. I would imagine an oil seal leaking enough oil to blow smoke would quite possibly cause excess friction and overheat the bearing also. Oh well, all in the past now.
Seeing as though the thread has been revived already i also have a question to ask
I have recently built up an sr20det for an s14 running a high mount gt3082r with cp pistons and cp rings, acl race bearings etc and we have done roughly 300kms on a rich run in tune with rev limit of 4500rpm
wen we got it back from tuner (engine ran for no more than 2 hours on the dyno, probably about 1 hour really) we did an oil change (20w50 mineral oil) but wen i opened the oil cap a small wiff of white smoke came out of the rocker cover, didnt think anything of it..
a few hundred kms later, it never did it again, doesnt blow any smoke at all either, we actually noticed the turbo was starting to spool abit earlier also, there is no piston slap at all wen hot, sounds like a stock engine, if not quieter!.. but has a very tiny amount of piston slap wen cold, can only hear it if bonnet is open and ur head is right ontop of the engine
anywho.. the tuner is booked out for a full rpm tune for another 3 weeks
so my question is, will it make any difference to the way the rings bed in if we keep "running" the motor in on this tune with 4500rpm limit (boost just barely comes to 0.7bar at this rpm) or should we cap our kms to 500km till we can put abit more boost through it and higher rpm (7000 or so)
thanks
Edited by snozzle
that sounds a bit dodgey,
been hearing quite a few bad things about their "hiflows"
It was out of warranty anyway, but you could argue that with the tiny amount of use it had gone through it was unacceptable. There's lots of cases of items being replaced outside of warranty because the failure was deemed unreasonable.
I had a second opinion here in Adelaide as well and the bloke I spoke to said even if it had no water supply and running at 20psi (I was running it at 10psi) that it should have lasted longer than it did.
thanks
I'm also curious to see some opinions on this.....
I'm far from an expert on this but I would imagine that it could only make the rings bed in better not worse by 'continuing to run it in'. I imagine however you would obviously cause greater wear on the bores/bearings due to running a shitty mineral oil.
Perhaps do a compression test, if all is well then just dump the oil. Definitely wait for someone with some first hand experience to pipe in before doing that though.
If the rings are bed, theyre bed, simple.
Driving it around as it is isnt going to hurt it at all...you'd be quite safe to bump the rev limit up some as long as the tune has sufficient fuel in it etc...if its not tuned then leave as is but youre not going to hurt it...
Need to be careful when running in new motors on RICH RICH tunes as this can wash the bores and contribute to them glazing...
Had enormous issues many years ago with a red top SR20DET built by Chris Milton Engine Developments in Adelaide...they rebuilt it using stock pistons which was fine with me, however, the piston to bore clearances were way too big and it was chewing through rings after only a few 100kms...after having the thing in and out several times, forking out sh1tloads to have it run in properly on Engine Dynos etc, finally had a Piston drag test done and the piston quite literally just fell through the bore...Lol...ffs....amatuers! Ended up in small claims court...settled out of court...small consolation after all the fvcking around!!!
Another problem caused by massive crankcase pressures as I had above is shagged Turbo rear oil seals.....was chasing my tail there with that one for a while! Smoke, smoke and more smoke!
The rings were bed in probably within the first 50kms of driving it, if you gave it some good hard squirts.
You need to understand that piston rings only seal properly on the power stroke, every other stroke they are virtually dragging in the bore. They rely on the rapidly expanding gases from the burning of the mixture to get down in behind the ring itself and push it down on the ringland/seat and out against the bore(hence why top racers usually gas port their pistons for increased piston ring seal). By running low boost and driving it like a girl the top ring isnt going to be doing that job as well as it needs inorder to conform the bore to its shape to seal properly.
You only need to give it about a dozen good 3/4 boost/rpm loaded pulls and they will be right. All done and then you are ready for a proper full tune and go flog it. When I rebuilt my rb25 3 years ago my tuner wanted me to baby it for 1500-2000km till it all "beds in". I argued my point and in the end I just went and did a couple of burn outs and flogged it around the mountains a couple of times and changed the oil a few times. Luckily he never checked the odometer, so I just told him i did it and then got it fully tuned. The motor has been perfect with no oil use or smoke over the last three years. I run acl (ross) pistons in it too, good piston and ring set!
There was a good article somewhere written by a motorbike guy in europe or america on how to 'bed in' your motor properly, it was linked via the gtruk forums i think.
well we havent been babying it, car actually does quite alot of speed in 5th even though its only 4500rpm rev limit
thanks for the input guys, pretty much confirmed what my thoughts were already
full rpm tune booked for april 12th ;)
lambos come off the production line and directly into a dyno room according to the mega factories ep, after the engines are assembled they are thrown on an engine dyno also. though they never say what kind of fluids are used when doing it.
I dont think anyone would suggest doing burnouts to run a motor in mate...giving it some stick through the hills, no problem, but static burnouts?
Rolls, audi and lambo have a "mega factory's" ep dedicated to each one. i believe they cover running the engines for the first time.
Please tell me that's on normal tv not foxtel?!
    • Good points thanks. Unfortunately I can't seem to rename this or delete the topic. Seems like I'll ask the moderators to change it or delete it.
    • You might want to update the thread title.  V37 ≠ V36.  And it probably isn't a G37 unless it is 2012+ Ininiti or LHD.
    • Just a basic run down of the relevant bolt-ons. All e85 First graph 406.9whp is HKS GT-RS, HPI manifold, 3" bell mouth dump / 3" straight through fake cat / 3" all the way to the rear and no resonators, nismo 740cc, walbro 460, oem RB26 itb's, power fc, eboost2, Greddy Spec M fmic, poncams, Turbosmart actuator, splitfires, ARD 150amp alternator. Blue line is same as above but Blitz Dual SBC (before i upgraded to eboost2) and 100cell "high flow" cat. Red line is after installing eboost2 and the fake 3" cat (it's just a 3" pipe with a cat shell welded onto it). Huge gains in response, as can be seen. Black dots are a mates sr20 with almost identical setup but uses a garrett 2871 instead oh HKS. Next grapghn 466.6whp is same as above, but HKS 2835 Pro S with the larger .87ar turbine housing, the special HKS Pro S dump pipe into a HPI split dual 2.5" front pipe and the rest stayed as is. Red line is after I welded the actuator brackets. (It was originally bolted together and was moving a couple millimetres under load). Green line is obviously before I welded the bracket, no other changes. 100whp gain at 3750rpm, massive gain for such a simple fix. Third graph is my current setup, huge changes. 469.7whp R31house twin scroll manifold, twin TiAl 38mm gates, Forced Performance (USA) HTA3076 with 1.01ar twin scroll rear housing, Link Fury+ and loom by 12volt, PRP trigger kit and r35 coil kit with r35 splitfire coils, HKS step 1 vct staggered cams, new oem lifters and performance springs, 49mm itb's w/port matched Nismo plenum, twin walbro 460 surge tank setup + 1650cc injectors, HKS Type R S13 600x300x103mm fmic, individual egt's, 4" turbo back with no resonators or cat and AES true straight through muffler + 4" butterfly off the dump pipe lower 90° bend. It's a preliminary tune with no boost control with using 20psi gate springs and 4" butterfly closed. Once body loom and PDM is compete, will go for 30psi tune.
    • Power light apparently functions as a transmission error light, you can try the power sequence to read any codes from the transmission control unit.
