Topgear australia what do you guys think of it?
to me their attempt of copying the great on screen trio of the original Topgear is very poor.
They try to argue just for arguing sake! It just doesn't seem genuine?
I still watch it though cause its nice to see some cars that we can actually get in Australia
they had the 370Z on there and the new GTR got 2nd around the track with the stig.
https://www.sau.com.au/forums/topic/289807-topgear-australia/
Top gear (UK) works 'cos of the chemistry.
The Australia trio come across as fake and false....they are just trying to hard instead of creating something which is unique to them.
Nobody watches Top gear UK for the in depth technical stuff or even 'objective' car reviews, it's more about the trio (their chemistry and challenges) and the cars are just props.
I couldn't agree more. I watch Top Gear UK because the three presenters have an incredible chemistry and they are very, very entertaining to watch. If I want to watch a car review then I'll hop onto www.autocar.co.uk or I'll watch 5th gear (incidentally, the Jason vs Tiff segments are very entertaining also, and those boys can DRIVE!).
The aussie Top Gear just didn't have the same chemistry as the UK show.
The problem with these other versions of Top Gear, not just the Aussie one, is that they should've found people with their own chemistry, instead of trying to find people with similar personalities as the originals. Instead, we get the older quipping guy, the young 'hip' short one, and a middle aged guy who 'shouldn't be cool, but is.
The US one would've probably lasted a lot longer with perhaps Jay Leno as the host.
I watched a subbed version of the Russian one a few months back and it was absoloutely woeful.
instead of top gear oz
they should have gone in a different direction to the uk top gear
name it somethin completely different (think hungry jacks is to burger king)
new presentation format (i dont know 2 shelas and 2 blokes)
not have it in a shed/studio with the crowd around like the uk version, and
challenges which are not so blatenly scripted or unnecessary or pointless.
the biggest issue is everyone does compare it to the original top gear show from the uk.
i'm ranting now - i must get back to work...
The aussie show is like that because it is scripted by owned by the the bbc who own the british version
the aussies have no choice but to follow the formula from the uk .
Pity we only have 1 decent guy on the show (James Morrison) the other 2 are complete f**kwits
  • 4 weeks later...
  • 2 months later...
instead of top gear oz Nup - I'd still run with this patent
they should have gone in a different direction to the uk top gear Yep - go for contrasts rather than risk comparisons
name it somethin completely different (think hungry jacks is to burger king) Nup - you can still stick to the patent 'n use Aussie Humour
new presentation format (i dont know 2 shelas and 2 blokes) Yep - Roy & HG & Corinne Grant for example...
not have it in a shed/studio with the crowd around like the uk version Hmmm - perhaps the 'Castle' next to da airport?
challenges which are not so blatenly scripted or unnecessary or pointless. Destroy Camrys rather than Caravans?
the biggest issue is everyone does compare it to the original top gear show from the uk. Yep - Drop the comparisons > Go for contrasts = Drop the word 'Stig' > Use an Aussie driver'n call him 'Wombat'
i'm ranting now - i must get back to work... Hmmm - me too...
I do think similarly to you Daniel - 910trx !!!!!!!!!!!!!!!!!!!!!
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
