Today all lower arms got the same satin black touch like the SPL ends. Very classy. I like!
The Kouki lights are on. Super fit. I also changed the pins in the new boot lock assembly so I only have to use one and same key to all locks.
Lots of action in the garage.
The head is improved one step further.
To eliminate fuel surge problems and fuel capacity at the track and during heavy acceleration, a surge tank is installed together with two Bosch 044 fuelpumps.
Included with the new Kouki lights, I got a new and longer boot lock-assembly. I do not want to have more than one key so I made a nice and easy modification.
Here is how to do it. I made a small "how to"
Enjoy.
What will happen when the fuel pump in the tank will suck air instead of fuel?
This could happen when you are on the track or during heavy acceleration. The fuel is forced towards the side of the tank, away from the pump. Especially when the tank is not full.
The air will be pumped into the fuel line, onwards to the fuel rail and via the injectors into the engine.
Most of the time this will cause a noticeable decrease of power and it may also damage your engine.
To stop air entering the fuel system, a surge tank / swirl pot is a very good solution.
I have tested a couple of designs and found two really well working versions. Which one to use is mainly a question of available space. Some install it in the boot, others in the engine bay. I will put mine in the engine bay.
If it is installed in the boot, use Teflon hoses. They are more gas tight compared with ordinary steel braided hoses and will prevent the smell of fuel inside the car. They are also resistant against E85.
To connect the hoses to the surge tank / swirl pot, use AN-connections. Usual sizes like AN-6, AN-8 or AN-10.
The installation is fairly simple. Remember the high pressure pump need rather much power and should be connected over a fused relay. It is recommended to use the ordinary pump power feed as relay control signal.
Boot installation
Engine bay installation
Bosch inline pump (0580254044)
Installation Diagram
Got a Haltech solenoid to control the boost very accurately at each load point.
This is how it will be installed but with the exception that I will use two external Tial wastegate valves.
Well done man. Any chance you could translate that for us? Lol
Breefly it says:
You will get lots of women with this car when the new bumper is mounted. All men outside the Monte Carlo Casion in Monaco will envy it when you stop outside to let the parking staff fight to be the one parking the car... lol
Naah.. It say that I wonn round 5 in a competion to have an area and free stay at hotel at an annual exhibition (car show). They are impressed by the engine and all the other stuff the car has undergone and they like the project thread and crisp photos. Sorry nothing about fame and fortune...and women :nyaanyaa:
  • 4 weeks later...
Picked up my new Tial waste gate valves from Svensk Turboservice yesterday. They came straight from the Tial assembly line in the USA.
Worth waiting for! They are the new, upprated version with integrated water cooling.
How small are they? I compared them with the earlier bolt on 38mm Tial WG and I can tell you. They are very small! Good! Since I do a twin installation and there isn't much space to talk about.
MV-S V2.0
This revamp features water cooling ports, three bottom air ports and two top air ports. Water ports are not required for operation, but come in handy at road racing, the top hat is close to the turbine housing/down pipe or when the engine bay doesn't get a lot of airflow. Air and Water ports are clearly marked so there is no confusion.
(mine are silver/aluminum coloured).
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
