  • 3 weeks later...
Bought a large box of oil.
(8 l engine oil) Motul 300V Competition 15W-50 Racing lubricant for racing cars
(5 l gearbox oil) Motul Gear 300 75W-90 Racing gearbox lubricant 100% Synthetic – Ester based
(6 l LSD oil) Fuchs Titan Race Gear 90 LS High Performance Limited Slip Diff Oil (formerly known as Silkolene BOA 90 LS)
(1.5 l brake and clutch fluid) Motul RBF 660 Factory Line race brake fluid
The original watercooled oilcooler, mounted on the engine block under the oilfilter, is sometimes creating a problem and has to be removed. It could be a problem with the function, available space etc. In my case the reason is a heavily tuned engine with high boost pressure. This create a very high local temperature rise. Let us call it a local thermal water explosion. This local temperature rise create a high local pressure in the cooling system and this could make the original oilcooler crack and cause a water/oil leak.
There are some ways to solve this problem, this is how I chose to do it:
Original oilcooler is hidden under the intake manifold and behind the alternator.
Original oilcooler. It is mounted on the block with 4 bolts.
Here it has been dismounted.
A close up to show how it looks behind the oilcooler. It is important to remove all trace of old gaskets and paint. The mating surface must be smooth and clean since this is the surface where the oilfilter/sandwich plate is sealing snug and tight.
In the centre you can spot the original stud. This is to be dismantled (twist it out like a screw).
Original stud dismounted.
In Nissan FAST software, part 15213P is found. This part is only used on engines without an original oilcooler mounted on the engine block.
It is named "Stud, oil filter" and Nissans part number is 15213-V0711.
Stud, 15213-V0711, mounted in the block (the four bolts and the gasket shall be removed).
Now you can select if you would like to use only a filter, an external oilcooler, a filter relocation kit or a combination with all of them.
I use them all.
Oilcooler thermo plate.
Mounting an oilcooler and a thermo plate.
Filter relocation kit.
Yesterday I was informed the new R-tyres are on their way and they should be delivered to me today. The flush fit wheel air valves have also been shipped. Soon time to get it all assembled and balanced. Exciting :P
I have that kind of valve on my other wheels too and they bring a nice touch to it.
It turned out very well with the flush valves on the new wheels I use for the R-tyres. Pictures to be posted after next round in the garage. I will have to remember to always keep the air fill adatper in the car from now on.
When the tyres were mounted on to the rims, they had to pump them up to more than 4 Bar of pressure. It sounded like a big cannon in the tyre shop. My poor ears...I wasn't prepared at all... at least not when the first tyre went on.
Mounted some parts. It will be ok but as shown, there is lots to adjust regarding wheel alignment and I will also adjustthe track both front and rear. At the rear, there is plenty of Camber but still a slight gap between the tyre and the fender. At the front, there is also some space for adjustments. I will decide how much I want to slam the car when the coilovers have settled. The steering angle has improved with the spacers mounted on the inner tie rods.
  • 1 month later...
It is named "Stud, oil filter" and Nissans part number according to Nissan is 15213-W040A. I have ordered one and will test it to be 100% sure it is the correct part.
The valve I will mount in the filter holder.
Stud, 15213-W040A, mounted in the block (the four bolts and the gasket shall be removed).
I use them all.
Some OEM-parts I picked up today:
Holder for the license plate lights.
Fasteners and washers for the camshaft brackets (total 24pcs of each).
Over pressure valve and oil filter stud to remove the OEM oilcooler.
Fasteners, washers and nuts for the outgoing drive shafts on the diff flanges (total 12pcs of each).
Fasteners, washers and nuts for the prop shaft on the ingoing flange on the diff (total 12pcs of each).
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
