Led Drive Lights, What Do You Guys Think Of Them?
If it actually sounds like this, could be a blown head gasket. Not having any overheating issues are you? -
FWIW, I got about 20 out of the RS4s. I liked them....until I didn't.
That looks like a really good price. I didn't call around, so I was relying on this for pricing - https://www.beaurepaires.com.au/tyres/yokohama/yokohama-advan-neova-ad09 Have you put many K's on them? Any chance you'd be able to estimate how many K's you'll get out of them? I suppose this is the big difference, if I'm taking the skyline out it's for a fun drive and fuel economy / preserving the tyres are not really front of mind lol. I had read so much on other forums as well where people were saying how long lasting the RS4's were on track that I think my expectations were probably just set to high. -
The pictures are a little confusing. 1. I was under the impression that GT4s did not have traction control. So why do you have a traction control throttle body on your crossover pipe? 2. Ditto, Stageas, even turbo Stageas, do not have TCS either. 3. What engine loom are you using? The original car's, or the one that came with the engine? Are you sure the one that came with the engine is actually from that engine? See question 2.... There are 2x grey loom plugs on that part of the engine. One is on the loom and clicks onto the Neo's boost sensor at the rear of the cam/coil covers. The other hangs off the traction control motor (front side of the crossover pipe, down low) and runs left and forward to a bank of 3x loom plugs located at the front end of the plenum. But depending on the provenance of your loom and the engine and that crossover pipe, you might not have everything. You certainly have things you shouldn't.
Gtr/gts4 is definitely smarter to pull the engine out be cause you need to pull the box out anyway gtst I’d leave it in and drop the cross member
