As title states, selling gear I have lying around. Was going to put on my car but due to selling car no longer need them. All parts have come off or suit R33 RB25DET Series 2….
Make me an offer. All prices Negotiable.
1x Power FC with Hand controller - No box, No tune - $1200
1x Z32 AFM – no plug - $180
1x Complete set of 4 Cusco Coilovers – unsure of age, model, spring rate (came with car when imported last year) – Height and Damper adjustable (no C-spanners) - $800
1x No-name High-flow Cat – 3" - $50
1x Complete set of 6 stock Coil packs suit series 2 RB25. 80,000kz - $150
1x Stock dump pipe - $50
1x Stock front pipe - $50
1x Stock side mount intercooler parts. - $100 the lot
1x Stock clutch and flywheel. Could use a rebuild/machining. – make offer.
I will send photos on request. Pick up prefered for larger items. Delivery is an option at the buyer's expense.
Please contact me via email ([email protected]) or mobile (0401769503) as I mighten be able to answer questions straight away via pm or post
will also have my '97 R33 S2 for sale shortly. Email if interested
https://www.sau.com.au/forums/topic/289913-garage-cleanout/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
