How many hours went into that? 1000-2000hrs? I would hate to think of the total cost. $200-$300k? Friggin awesome. I love how integrated and snug fitting the roll cage is. Oh and the dash, how cool was it?
Talk about the ultimate E30 M3 though! That one is a keeper!!! Love to see it in action at a track.
From the looks of it, seems it was built with motorsport intentions. Possibly tarmac rallies but I'm only guessing. Was this built in the USA? It was left hand drive.
All E30 M3's were left drive only.
I'd be interested to see it on a track too, I think it would stand a good chance of being a lead tipped arrow.
Would lay hella skids though and be lovely as a static display for the man who already had everything :)
I'd think so too, but still cool :)
nope weight distribution is supposed to be spot on (they mention it somewhere in that thread)... firewall is been extensively modified, engine sits pretty far back and is only 5 cylinders long... all alloy too where as original motor was iron block
I just reckon they need to get more tyre under it... It needs 10 inchers at least with that amount of hp... he is talking about a 650bhp stroker kit too
awesome. Just awesome. I'd love to have the time, dedication, and money to be able to undertake something like this.
I never had the time to even do a bloody service on my own car..let alone such a detailed build!
Ahhh, I'm guilty of not reading it and will gladly stand corrected :)
Looks like a pretty basic, budget build up. Might try that this weekend with my mates in the local village using tuk-tuk parts
LOL make sure you post pics of the result :)
Also re the comments about the weight....despite being a massive engine in terms of size it would be very interesting to compare the V10 weight against the original motor.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
