hey i have not been driving my skyline for the past 8 weeks and so i when and started it and everything was fine then when the temp got up to round 80 85 it wood start to miss and batt light wood come on so i wood give it a lil rev wood still miss then go away, but come back and batt light wood come on. i have put new $114 plugs gaped to .8mm and coil packs??
car has wolf v4 and is rb25 to any ideas?
post-62191-1254207793_thumb.jpg sorry about bad pic
and dose any one have a pic of there dash lights when key is turn to on as i think only 2 of myn work hand b and batt
Edited by mr turbo
https://www.sau.com.au/forums/topic/289937-r32-gtst-dash-lights-and-missfire/
could be something simple, or could be a bit more serious, but i'll just list the simple stuff.
stale fuel
moisture in the coils (or a plug for a sensor)
fouled plugs (were the new ones put in after the problem or before it was parked for 8 weeks?)
alternator playing up (possibly due to dodgy wire or moisture, or it is just cactus)
there are other things but you need to do a bit of diagnosing first to rule out a few things and get a bit more info
  • 3 weeks later...
alternator is fine new plugs and battery still doing this but only when it gets up to runing temp???
if some one can send or post a pic of a r32 dash with key turn to on that wood be the best as i dont think all my light light up
thanks
heres my one, door one also lights up but i took the photo with the door closed...
sorry about the shit quality, i just remembered this thread when i was starting the car so i took a pic with my phone.
hope this helps you.
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
