Gday all
Just need to check on what warning lights people have, mainly on a manual series 2, On mine i don't have a hicas light but i do have a 4wd light with the little s in the middle and as
far as I am aware the 4wd light is only on auto's? The light is in the bottom left of the cluster.
I am having a few issues with my hicas and the 4wd (s) light has come on a few times and it has got me thinking (confused)
So if anyone else has a manual and a 4wd (s) light (good) if not WTF
cheers
https://www.sau.com.au/forums/topic/289945-warning-dash-lights/
get under your car at the rear... between the to rear wheels... there should be something looking like this... this is hicas... im fairly sure all rs4s have them... my 260 does!
on the cluster its the bottom left hole is hicas and next one is 4wd.
my s2 auto has that button with 4wd S on it... thats a center diff lock... unsure if maunals have this... i doubt it but may be wrong.
what problems are you having...???
with acc power you WILL get hicas and 4wd light. until it checks its all good like all other ones.
above all rip out your cluster and see what you have... i gota fealing they block out the ones your car wont use (lights)
if you have hicas but dont think its working or somthing most likely your allingments pretty ghetto spec.
theres a hicas diagnositc around+
a quick google showed all manuals have hicas... id get a $99 lock back and be done... fk it right off lol
Edited by chef_stagea
yeah i defiantly have hicas under there.
The hicas pump is getting pretty noisy so i am taking it to the mechanic on Friday to see what our options are. I would rather keep the hicas if at all possible.
As far as the lights are concerned I have a 4wd with the little s in the middle on the far left then i have a 4wd light next to that they all light up but i am starting to think that where
my 4wd,s light is it should be hicas. ehter that or the hicas light is there but in a different spot and not lighting up due to a major problem which according to the manual does happen.
Or i have a auto cluster with manual surrounds to cover the gear lights :P which worries me!!!
mine has a hicas light . "hicas" . has a 4wd light . "4wd" no s in it . yours sounds like its half an auto or something . shouldnt have the 4wd light with the s in it as autos have this and its syncro . makes 50:50 torque split front and rear . manuals done have it . got a pic of your dash when you turn the key on and all the lights turn on
i dont have a manual cluster but that light with the 4 wheels and axel image with the "S" in the middle is the light that lights up when you press the centre diff lock/syncro button. the 4WD light is beside that one on the right and is a yellow light that just has 4WD on it. do you have a centre diff lock/syncro button, its right beside the rear de-mister button.
Edited by QWK32
noisey hicas pump??? hmmm there isn't a pump, its an electric actuator. its like a big windscreen wiper motor that controls a linear actuator. are you sure its not you 4WD pump, its at the rear of the car, drivers side i think.
yeah sorry hicas motor, when i pull up it ticks for a couple of seconds, the other day i pulled up and it kept on going so i jumped out and the hicas motor was the only thing vibrating.
(black wiper motor looking thing hanging off the diff)
sounds like i might have a auto cluster, I checked all the screws around the cluster and they all look as if they have never been touched so i thought i would put the question out there.
No there isn't a 50/50 lock button which is a shame, not sure what i would use it for but would be cool!!
u my friend have an auto cluster.... what i would be doing is running the hicas diagnostic... or unpluging the cords at the hicas unit... this MAY get the 4 wheeled 'S' symbol staying on... this confirms you have an auto cluster i spose...
open your boot... right hand side little flap open it... and sus ur 4wd fluid resivour!...
the s one is the center diff lock... ONLY found on autos...
i have a hicas unit you could probly have if u wanted.
don't know if it will help at all, but I had both the hicas and the 4wd light on at the same time (and my car now has no HICAS, and has been converted to manual). It was the only time I've ever seen them come an, and it was due to low voltage from the battery.
Admittedly, the wiring in my car will prpobably be a bit differentto yours, but it may be worth checking your battery...?
Doesn't the "Auto Cluster" have the gear sellector possition between the tacho n the speedo. ie Park, Reverse, Neutral, Drive etc
Maybe someone has changed that window.
the silver bit that covers the dails will be a manual one and will cover up all the "p r n d 321" on the auto cluster as it doesnt have the slot cut in it. my rs four s dash has holes for all the auto lights in the back of it
not to sure what the go is, normally i would be leaning towards the km's wind back, but the condition of the seats, steering wheel, pedals and everything else makes me think other wise.
as for the auto to manual conversion, yeah maybe, anything is possible!!!
I have also had a similar problem, after we got mine going with the fresh paint in the engine bay all the earths where not making good contact, constantly had the 4wd light on. Ended up scratching all the paint off and problem went away.
Hi can anyone tell me if my R33 1995 model has a fluid reservoir in the rear of the car for power steering fluid.
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
