As the topic indicated i have misfire at about 5.5k rpm and have got a second coil pack that i want to fit. However i only want to change the faulty coil. How do i diagnose which is the faulty one?
I would rather not run the car 5 cylinders red line the crap out of it
Any ideas?
Thanks in advance
https://www.sau.com.au/forums/topic/289958-help-me-diagnose-my-faulty-coil/
Usually the problem is a hairline crack in the coilpack body which allows the spark to follow the path of least resistance and arc to the head. Remove coil cover, move car to a dark place, start car, get someone to rev it while you try to spot which coil is arcing out....replace.
Moodles2 can you please elaborate on your post. You saying to buy a cable and run it from the ecu to the COMP and i need the program? Where can i download/ buy the cable?
I'm not sure if it will spit out any fault codes cause the check engine light doesn't come on, it is only really mild miss fire but still need to fix it!
If you have an R34 - Better get a set of new coils (splitfire brand). Once one coils starts to fail the others will not be too far behind.
Best get a new set it will save you hassle especially if you drive far from home alot.
This only applys if you still have the stock ECU. Your Skyline has a fuse box under the steering wheel, inside is the Consult port (aka diagnostic port). With a Consult USB cable (http://ecutalk.com/interface.aspx) you can connect a PC or laptop and read sensor values, do active tests etc as long as you have PC software like OBD ScanTech (free) or Nissan DataScan (commercial), this is a screen shot of Nissan DataScan (commercial version not the cut down evaluation version) with the page to cut off spark to cylinders, effectively disabling them.
the problem with using the consult method is it isn't that reliable for what he wants to find out. at idle the weak coil may be firing fine and simply switching of cylinders won't find the dodgy coil.
swapping the coils out 1 by 1 will give the most accurate results, however if more than 1 coil is failing then it won't help much.
also, before you start swapping coils around, how old are you plugs, what gap are they, what heat range and what type are they? if you plugs are getting old and worn then they may be the problem and not the coils. in my case when i had a missfire it was caused by the plugs and not the coils.
far out i'm confused! lol yer well tonight i'm gonna pull it all apart and see wats happening under there :thumbsup:
Only problem is that it doesn't constantly miss! Last night on the way home it was running fine on full bost and the the red line, but the day before it was missing!
is the r33 series 1 coil pack the same as the series 2?
Edited by P1OTR
s1 has a seperate ignitor pack (same as r32). series 2 have it built into the coils (same as r34).
Thats right, I put r32 gtr coils in mine wen I had a miss. But does that mean all rb26 coilpacks are the same? or will the r33gtr ones be like the series 2 coils?
so in short i can't put an series 2 coil in a series 1?
nah man u cant, they simply wont ignite.there will b no connection.
series 2's hav their own igniters on each coil pack but a series one only has the one firing up all 6
the r33 gtr coils i have seen were like the s1 and r32, but i don't know what year series gtr it was.
ah true,,how many series 33gtrs are there? and wat r the differences
I have a set of s1 coils somewhere, what side of town are you Peter.
hey, he's mate of mine, he's down Narre side.
Ey Piotr,i got 4 good spare coils if u need, but if ur closer Madbung, go ahead
    • Well, in the same way that you can't tell any SUV from any manufacturer in any size category from any other one, "sports" coupes now all look identical. Stand back and squint your eyes and the Supra and the 400Z and the GR/BRZ things all look the same. I was just thinking last night, when sitting behind a Subaru CrossTrek, that I have no idea what it is, how it differs from an XV, or a Forester, or an Outback, or anything else Subaru offer, and I couldn't tell if it was supposed to be small, medium or large. I contrasted that to the good old days, where a HQ Kingswood had familial similarities to an LJ Torana, but there is no way that you could confuse them, and how a bit later, the HX Kinger and the concurrent Torana and the Gemini all had familial similarities, but you still could not confuse them. Ditto the ugly Fords and Chryslers of the era. But now, a RAV4 looks like a Kluger, looks like a Yaris/Cross/whatever they're calling those stupid f**king things, looks like every other Toyota that's not a Camry/Corolla sedan.
    • The Prelude doesn't look that bad without all that lens distortion in those pics. Makes it look disproportionate when it isn't. Actually I kind of liked it at the Osaka Auto Messe earlier this year.
    • Pour in the highest octane, non-ethanol fuel you can get and see if the readout changes. If it's dead bang on 11% then I would question the sensor. Another quick test, just take it out and run normal (in an american accent) gas-o-line through it and see if the sampled ethanol or lack of changes.   United E85 here in the land of drop bears does vary a bit, I've had as high as E87 (could be water in their tanks too, who knows)
    • Yep. And if you ever do, you'll just have to deal with it then.
    • E10 is pretty tightly regulated in percentage. Too much and engines can't adapt. Every incentive is against them to have too little ethanol though. The more ethanol the higher the octane.
