147rwkw RB25DE
"Amazing results with a nistuned Z32 computer modified to run the R33, this cheap alternative is conducted in house and retails for $1300 fitted and tuned, as the R33 computer is not a chippable board. the first run is standard setting with aftermarket exhaust 96.3 kw, then after a nistune chip and tune 121.5 kw! then a set of camshafts and a nice set ENVY Dyno vernier cam gears inlet and exhaust doing away with the variable valve timing showed amazing improvements @ 147 kw! thats almost the power of the turbo engine kids!!" copy paste from the vid URL
Edit: didnt let me embed
Edited by Super Drager
https://www.sau.com.au/forums/topic/289962-take-a-look-at-this-beast/
Good effort, that'd be a fun drive.. total cost including all parts, labour and dyno?
My guess is if you throw that kind of coin at a gts-t you'd still be 100kw behind
Edited by madbung
Not sure on the total cost, but i suspect somewhere around the $4000 mark. Yeah thats true but for an N/A its a good effort.
Edit: Around 4k as its cams, camgears, nistune+tune etc etc someone correct me im probably way off.
just creamed a little bit...n/a powaaaah :D decent number....anyone seen any other n/a skylines pull big numbers?
Quite a few RB25DE's in the 120rwkw-130rwkw range but i've never seen one crack 200rwhp until tonight.
actually you still haven't, LOL. he came about 3hp short.
and while it is a good effort for a NA, having thrown 4k of mods on has only gotten it to a point where a stock turbo would be.
also they don't have the car tied down very well (if at all) which would probably also increase the power reading. the reason i saw that is that the car moves around a little bit at about the 8 second mark in the video, and i have seen much more powerful cars than that move around less.
MUST you ruin the fun? :(
Hey mate how much duration and lift were the cams?
And what is the maximum lift for an rb25de?
Cheers
Hey mate, i'm really not sure but i wouldn't expect them to be much different to Poncams.
