Highflowing turbo shortly, unsure which way at this stage. Either the Hypergear or GCG. Aim is up around the 250RWKw mark.
http://cgi.ebay.com.au/EXEDY-HEAVY-DUTY-CLUTCH-SUIT-NISSAN-SKYLINE-R31-32-R33_W0QQitemZ220486916671QQcmdZViewItemQQptZAU_Car_Parts_Accessories?hash=item33560b5a3f&_trksid=p3286.c0.m14
Any ideas what kind of output this clutch upgrade could handle?
Searched around cant find any output ratings.
Cheers.
https://www.sau.com.au/forums/topic/289965-exedy-heavy-duty-clutch/
Ring Jim Berry and ask him about those , I believe it's what I had before I had one of his custom clutches fitted .
Don't quote me but I think there was some mention of the pressure plates cover not being as good as the OEM R33 GTS25T one .
Worth the call , cheers A .
Yeah the exedy one is not as good....it won't explode like a grenade
And hopefully you aren't getting the clutch in the picture. That one suits a Toyota
nah not that one exactly:) trying to get an idea of what budget ill require.
i dont see myself spending 3-5k on a turbo (plus everything else), so i dont see the point buying a shit hot clutch capable of 300kw+...
nothing gives output ratings so its a bit of a mystery what ill need. stock clutch is struggling with the 200kw i got now..
whatever can cop up to 250rwkw without slipping should suffice.
NPC Bigmouth clutch FTW
what?
NPC - Nick's Performance Clutch Service
Bigmouth Street clutch. They are an organic clutch and we have them in cars making 300rwkw. 6 months and heavy driving and no problems as yet.
Have fitted 5 of these myself and had 3 more fitted by people I have sold them to. Priced extremely well also.
Their number is 07 32779403. Ask for Doug
thanks mate. sounds good.
BUY MINE!!!
PRETTY MUCH EXACTLY WHAT YOU ARE AFTER
http://cgi.ebay.com.au/EXEDY-HEAVY-DUTY-CL...id=p3286.c0.m14
Cheers.
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
