recently i have noticed that the front windscreen has been fogging up at the bottom in the center, even in the middle of the day, but its almost a steam like fog that moves around, gets bigger n smaller n moves around a little bit but generally in the centre of the windscreen.
this also started with almost a burning smell everytime i turn on the air conditioner/heater
now today the temperature gauge was reading high and i found out there was no coolent in the radiator so i filled that up and it doesnt appear to be leaking.
the steam is still evident and the smell is still evident
it almost smells like a burning oil smell.
anyone know what could be happening or have had this problem before, im really hoping someone can guide me in the right direction here.
p.s did a search found nothing :P
i got a bad feeling your heater radiator has a leak in it...
maybe just a small leak to cause steam but no drips..
only thing i can think to test this is drive around for a little while with the radiator cap loose so the system doesnt build up pressure and see if it still does it. dont drive like this for 2 long and you will probably need to bleed the cooling system again after.
dont know if this helps but give it a shot.
yeah sounds like you have a leak somwhere in the heater box and that is causing the smell, the fog and the overheating and loss of coolant.
first thing i would be doing is disconnecting the hoses that go into the cabin from the engine bay so that you don't loose any more water and damage the engine. then find the tutorial on how to remove the heater box and have a look for signs of a leak
If i do keep losing water and just keep topping it up before it gets low i should be able to drive for a week or so yea?
i wouldnt baby it, as babying doesnt really change too much
i had a small leak in mine years ago, couple days later sitiing in peak hour morning traffic it burst and filled the cabin with steam lol was probably pretty funny to watch, but not cool for holding coolant.
really need to look at bypassing it quickly
quite easy to do, grab a set of pliers, and some steel pipe or the likes.
Disconnect the 2 pipes going into the passenger side of the firewall and then push the steel pipe into one of them and use the hose clamps that were originally used to clamp it, then connect the other pipe to the other end effectively bypassing the heater core,
I had this problem a little while ago, unfortunatly i was left with a nice wet patch in the passenger footwell!
Since bypassing the core i have no problems, and ill eventually get around to replacing it at some point, but i dont think i need the heater for the summer :whistling:
ok so found this
excellent tut on how to replace the core yourself
so i shall bypass is asap and then once ive got a free day will DIY it
heres the link for anyone who wants it, a very good read
http://www.skylinesaustralia.com/forums/Re...80#entry4864480
yeah i just felt mine 10 minutes ago, also got it.
thanks everyone for your help, this is why i <3 SAU
  • 4 months later...
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
