Looking For Sklyline Gtv35 300gt Stereo And Control Unit
peaceB
 Share
Hi guys,
I'm currently looking for a 2 din stereo unit for my skyline gtv35 300 gt 2001. I will need the entire front load cd stacker unit and also the button panel that controls both the air-con and the stereo. I would prefer the unit with the lcd navigation but without it is just fine. If you know where I can obtain one or you have 1 to sale, please pm me with contact details and price.
Thank you very much.
call me - easier. if you are trying to fit JDM navi where it should not go there is a LOT more to it.
I'll get my sparky to give you a call, thanks chris.
BTW, how much more work is needed if I was to install the JDM Navi when I don't have 1 in the 1st place?
Edited by peaceB
never heard back from there. I'll assume its done though.
I spoke to the sparky on friday arvo, asking whether or not they've got in contact with you Chris.
They said that they were organising to bring my car over to your workshop that afternoon.
Have they managed to bring the car over to your workshop yet? Did you get a chance to look at it?
never saw it. give them a chase.
I've got my car back today after 5 wks! thanks alot chris you're a life safer. if in future i need someone to speak to in regard to whatever i'll be sure to speak to you 1st!
you're the MAN~!
no probelm. I got it last night and spent a couple of hours on it. sorted it. if the SWC bugs you tell me. I noticed it was a bit dickey but didnt have one spare to swap in.
if you need a cruise control for it I have one to suit :(
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
