Any SAU'ers interested in a New HDTV 42" plasma purchased last month from Dick Smiths Tuggeranong (with proof of purchase). Looking for $700, Cost $888.
Check out the features/tech specs -Click Here!
PM me if your keen for a great priced big screen.
Deal on for 48hrs
Edited by Sinista32
~ As well as the standard direct connect multiple HDMI, AV, PC-RGB (computer) connection/s. It takes all sorts of other connections including USB stick, HDD and SD cards (via a media centre unit)
What no takers? :P
BIG PRICE DROP
Okay deal of the century $500 if you pick-up/pay tomorrow eve. Almost half price
After then it's all too late!
Edited by Sinista32
I dont believe you Richard!!! You posed as a girl guide, knocked on the door of an old grandma, hit her over the head with your cookie box and stole that TV didnt you!! :)
:jokes: :)
Grandma said "what big teeth you have"
Like to come shopping at Urambi Nursing Home? Summer Specials are on :O lmao
Im realy happy the skool uniform still fits!
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
