I love the look of the r34 GTT and GTR, but the GTR is out of my price range. I also really want the rb26dett and AWD, so what i want to know is, how hard would it be to convert a GTT to rb26dett and AWD? Roughly how much would it cost, and what is involved (besides the obvious)? Is it technically feasible to do, or should i just settle for an r33 GTR?
By the time you cover the cost of the halfcut, labor, and time you spend on the conversion / time you could wait and save money - the R34 GTR would be affordable anyway.
Or settle for an AWD with 25, and do some work. Plenty of avenue's for power, ie building an RB30DETT.
This general question has been covered so many times it's not funny. The conversion is not simply a matter of throwing a RB26 engine and gearbox into a chassis. There is a whole bunch of electronics and hydraulics that all work together to make it work.
The general consensus is that it is far cheaper - and much less anguish - to just go and buy the GT-R. Then again, you could start with a AWD RB25DE version, and drop the RB26 in. And add decent brakes. And decent suspension. And ...
Check the build ups pages, someone in there is doing it.
Depending on your skill level is possible "relatively" cheap.
But as said before, nothing wrong with the RB25.
    • HUMVEE are fine in big open areas, but they are problematic on the street and tight areas As for reliability, some of the  US Army guys I have chatted with have said that when they were working they were fine, but, the do spend alot of time in workshops for multiple reasons, admittedly, they did get a hard time by the boys and girls who drove them I would definitely put them in the "buyer beware" category  They do look tough as nails though
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
