Hi all, its me again with yet another plea for help. I'm hoping someone in the SAU community can help me out.
I have dropped my motor (from k frame) just to be able to remove/work on engine with ease. I am trying to separate the engine from K frame at the moment but I am having issues removing the front LHS shaft. Just wondering is there a trick to removing it?
Below are pictures of the shaft in question.
2725004050064171239GzawSb_th.jpg2922881790064171239vsbBER_th.jpg2549783640064171239eQzwKZ_th.jpg
Any advice/ help is much appreciated!
https://www.sau.com.au/forums/topic/290047-gtr-front-shaft-removal/
is that your driveshaft (ie have you got it out that far)? If not you pop it out by taking off the front diff cover and levering it from inside. Detatch the bottom ball joint and sway bar link to swing the strut out for the driveshaft to have enough room to remove it. Hope that helps
but if thos pics are not yours.....getting it started the first time can be really difficult, there is a ciclip in there to stop ths shaft coming out easily. lever it from multiple points between the slot on the driveshaft and the diff cover bolts with bid screwdriver / pry bar.
if you are that far out and stuck you must have it cocked at an anle somehow...straighten by tapping on the side of the driveshaft and it should pop right out.
unless you cant get it any further because the other end is stopping it....in which case doo doo covered it
You need to remove the outer end from the wheel hub first. That entails effectively disassembling the front suspension to get enough movement of the hub to slip off the end of the shaft.
Then use pry bars in the machine slot of the inner end to lever the shaft out of the diff. (no need to remove the diff cover plate).
BTW - that's the RHS shaft. It only appears to be the LH shaft because you are looking at it from the front.
guys,
having the same problem at the moment.
I have separated the shaft at the CV (grease everywhere), but cannot get the inboard part of the shaft out. Have undid the diff cover (only gotten it out about 15mm) hoping that once it is out of the way I might be able to get something behind the shaft end.
Can anyone help with exploded views / diagrams.
Ok well im preparing to pull the front passenger shaft on my RS4 Stagea as I've got a split inner CV boot :)
Theirs a good outline on page 10 and 11 of this manual for doing in for a gtr so think it should be much the same.
http://www.scribd.com/doc/4964854/GTR-Engine-Removal
    • I've sent JaseR33 a private message in the hope he gets an email and contacts you
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
